old gas can
jim
wi
the lady down the street was throwing out a plastic gas can. looked brand new so i picked it up. opened it up and it had the funnel and all the gaskets in tacked. bone dry. had only a hint of gas smell. washed it out with water and dawn. my question is what else should i wash it out with. want to make sure that there is no varnish deposit of any kind. can i take some old gas and swish it around and dump it out to make sure it is clean. would gas dissolve any varnish deposits that might be left in the bottom of the plastic can? thanks jim
Bondo
Greenfield, Maine
Ayuh,.... You've already cleaned it Way more than I woulda,.....
Bone dry, 'n no crud to the eye is clean enough to haul gas in,.....
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Throw some gas in it and call it a day. No reason to be that **** about a gas can. If you see no crud, you are good to go!!!
michiganman18
You did way more than I wouldve. I wouldve made sure no water or debris then filled it with gas. Voila
kd3pc
Northern Neck
You might check with your AHJ, some of those "old" cans are no longer legal for use in many parts of this once great nation.....the new ones have to be spill proof, vapor proof and the like.
You almost need 4 hands to use one, with out spilling, but I suspect that no one at the EPA has actually ever had to use one, if they had - they would have quickly discovered that using the new cans with two hands will CAUSE fuel spills.
The are now called PFC, Portable Fuel Containers.
G_P
Central CT
If its dry inside and not full of crud, just fill it up and use it.
Dont worry about the "gas can police" either. I've never heard of anyone getting in trouble for possessing an "old style" gas can.
LS6 Tommy
Northern NJ
They are not illegal to use, you just can't buy a new one that isn't spill proof.
Tommy
IFMJohn
Tacoma, WA
Tommy
My father seems to have found a website where they will ship old school gas cans to california. He's got like 8 in the last couple years. They are sturdy too, all metal, nice cans.
barnjunkie
TN
Prior to the existence of plastic gas tanks, the metal ones had a specialized plastic lining that would degrade over several years and fill the inside of the tank with debris. It was thought that making a solid plastic tank would fix this, and while plastic debris is not a problem, other problems have still arisen. When gasoline is left sitting in a tank for a period of months or even years, it separates, leaving a solid sludge at the bottom. Sometimes this sludge breaks up and is carried off into the engine by the fuel lines, which will clog the air filters very quickly. What's even worse, rust and bits of burned carbon can flow back from the engine into the tank. For that reason one should clean out gas tanks every few years--more frequently if the tanks contained mixed gas or are rarely used. Removable tanks, such as those that come with boat motors, motorcycles and lawn care equipment tend to be easier to clean. However, they usually hold gasoline mixed with oil and tend to be left sitting longer between uses, so cleaning them is essential. The tank should be removed from its moorings and drained of any fuel. The fuel itself should be strained through a thick cloth if one intends to use it again. Once empty, throw in a handful of screws, bolts and nuts as well as a quart of cleaning solvent. The best cleaning solvent to use is acetone, given its tendency to vaporize quickly. The metal will help to scour the insides of the tank free of anything that would stick. Seal the cap of the tank, and then shake it thoroughly before pouring out the solvent and metal. You may need to rinse out the tank with more clean solvent, repeating the process until the solvent comes out clear. Simply leave the tank--cap off--in a well ventilated area for a day. The solvent will have vaporized by then, leaving you with a clean tank. Integral tanks are the kind that can't be removed from an engine, or at least removed without the use a fully equipped automotive repair garage. To empty, all the gas the tank contains must be siphoned out. It's normal for a small amount to remain in the bottom. You will need a strong magnet on a pole, a handful of iron or steel ball bearings (screws and nuts will work), a tank of compressed air with a hand-held spray gun and a gallon of rubbing alcohol. The rubbing alcohol and the ball bearings should be thrown in the tank and agitated with the compressed air gun. Since you can't shake the tank, you have to shake its contents. This should scour the interior well enough. Use the magnet to retrieve the metal ball bearings, and then siphon out the alcohol. A small amount of alcohol will remain inside, but it mixes well with gas and the engine should have no trouble burning through it.
LS6 Tommy
Northern NJ
All good ideas except the rubbing alcohol. It's 30% water. I realize it would only leave a tiny amount of water, but using something with 0% water is even better...
Tommy
CJM8515
I was driving to help my cousin with his boat yesterday and saw a garage sale. I noticed there are 3 gas cans sitting out there. Stop, one is the old school plastic with yellow capped spout. They told me a dollar and I gave them 2, all the other cans were spill proof junk.
I am amassing a small collection of cans lol... New spouts can be bought on amazon that fit the pos spill proof cans, can even get them in cali under the guise of "water can spouts".
Jeremy77
Coastal Alabama
I've just "improvised" the locking nozzles on the last few cans that I've bought and they now work just like the old ones. There are a few different types out there but any of them should be able to "convert" with minimal tools or effort.
Jeremy77
Coastal Alabama
as to the OP.....like others have stated, just fill that bad boy up with gas and as long as there's no leaks, your good to go.
justme-
Boston suburbs
Those "water can spouts" come with different parts to fit multiple brands/types of can and even a vent that can be added if yours doesn't have one. Seems when the companies switched to making new style cans they switched to the same wolds for water containers too....;)
barnjunkie
TN
Juast as FYI - that excerpt that I posted earlier was copied off of the internet. I would never give that much thought to an old gas can. Just rinse it out 'til you feel a warm fuzzy feeling and go with it.
kbs2244
To the OP.
If you are still worried about it, all the gas "stablizers" (Sta-Bill, Sea Foam, etc) are mostly acetone.
Go to the local paint department and buy a pint, slosh it around, and pour it into your car.
txturbo
Rosenberg,TX
I would rinse it with acetone. It will clean, vaporize quickly and absorb any moisture that might be in there. Seafoam....haven't really found anything that it does.
kbs2244
Acetone is made from propene.
Proene is a hydrocarbon.
Propene is a byproduct of oil refining
Therefore they can call it “Made from Petroleum.”
Check Wikpedia
LS6 Tommy
Northern NJ
Check Wikpedia
Wikipedia. The end all to all knowledge...
Seafoam is a blended petroleum product. It's basically an oil. Acetone is a petrochemical solvent produced from Propylene. NOT the same.
Tommy
