Slab problem for two post lift
Jemezcrusher
Came to this forum from the Trifive forum. Those guys say youse guys are pretty smart fellers.
The two post lift I have recommends 4.5" re-bar reinforced 3500 PSI concrete. I may have 4", but my psi is 3000 and I would bet is re-mesh, not re-bar.
My thoughts are to cut out two 4x5' squares where the columns for the lift go. I would dig them out to 8" depth, and put in two 8" pilasters about 36" down. I would drill holes in the sides of the opening every foot or so in order that re-bar can be epoxied in to tie in the old work with the new work. Pilasters would have re-bar in them and tied in to the new 4000 PSI 4x5' portions.
Is this enough?
Is it over kill?
Am I crazy?
Jemez (hay-mez)
12ozd
at the kegerator
Denwood
Thunder Bay, Ontario, Canada
My slab "retrofit is documented here: http://www.garagejournal.com/forum/showthread.php?t=265806
One of the images I posted up (for a Mohawk 7000lb asym lift) dictates a 48"x144" slab that is keyed (no need to epoxy rebar dowels) under existing. I ended up doing a 14" thick version of below, so a very high safety margin for the MaxJax I was prepped for. The reference for the composited image I had posted is here: http://www.mohawklifts.com/consumer/library/Slab_Req-Reco_2-2010.pdf
sqft
Yes, thats about what I did for my Mohawk install. But it was 18" thick, rebar, and keyed. Probably way overkill, but I feel pretty safe when Im under a big car. I would not go with less than spec, what ever you do.
