I was not expecting an est of $7300 for vinyl siding and two new gutters. My garage is 25x36 one story with a 16ft door, pretty straight forward job I would think. that was double what I was expecting. Am I wrong? I priced out doing the job myself and arrived at a little over $1000 in material but I'm sure there will be extra costs I didn't figure so I gave myself a window of $1500-2000 for everything if I do it myself.
I figure a contractor would get the material cheaper than I could and then factor in mark up and labor I expected an est of $3000-4000.
Has anyone else received est for siding, was this quote out of line??
It was bad enough when it was cool out, but when it warmed up outside, good god, it looked like a hedge apple with all of the bumps. You also want to have either a table saw, or a power miter saw, a fine plywood blade mounted backwards. this gives you a nice clean cut. A blade running forward will chew up your siding.
Hope to see you there if you can make it.
