Jazzman442
I'm finally getting my 4 post lift installed. Is there any advice, Tips Trick's? Things to look for before they leave?
Any advice would be helpful.
Where is here? Might be able to help if we knew where!
Nice upgrades! I've been toying with the idea of the jack but so many things out there I want!
Had my Direct Lift installed a couple of weeks ago. Love it and no issues at all.
. What do you all do for changing oil? A sliding oil Pan, A Floor one or a regular Oil change bucket on the jack stand or solid cover?
I got just the thing for changing oil. I bought this unit from Northern Tool. It is PERFECT! Drains the oil directly into my transportation jug, and then I can easily take it to local shop where they use waste oil for heat.
I was originally looking at this model for the same reason you state. Does it wobble allot?
This is the model I have been wanting after seeing all of this. How do you get the oil out of it and into another container?
I'm still trying to find some one to install a high lift. I really can not believe this is that hard to do or find some one that knows how to do it?.....
LOL
Sorry Here is Central Florida about 45 North of Clearwater.
I made a rolling catch tank today. I bought the economic model from northern tool and welded on site guide bars. It can move north and south as well as east and West.
Note the drain valve for easy emptying. .. It was a few hundred bucks cheaper than the commercial one. In retrospect i should have bought that instead..[/QUO
You make me want to get a welder and learn how to weld!! LOL Nice jobIs it hard to empty?
Like I said, I considered one of this style. But you need to handle the oil an extra time, which is a PITA IMHO.
Also, on my oil drain, notice the elongated pan. I find that very handy because when you first remove a drain plug, the oil can piss out pretty good horizontally. The elongated pan helps ensure that you catch every drip.
Either style (and many others) will get the job done......
Cake to empty! Just hook up a hose and crack the valve. Usually empty in under 20 seconds!I made a rolling catch tank today. I bought the economic model from northern tool and welded on site guide bars. It can move north and south as well as east and West.
So one thing I'm missing in all of these pictures is the electrical connection to the 4 post lifts. I'm wiring up my electrical for my garage right now and I just assumed that the electrical for a 4 poster would be from above one of the 4 posts. Can anyone show me how your posts are hooked up to power??? Thanks
not much help on 4 post lifts on this thread?
what kind did you buy?
I am looking to go pick up a direct 8K lift this week. do you have any advice for me.
when I do my electrical, I will show you how I do it, but have no plans yet.
why did you buy the 9 verses the 8? $700 more. what vehicle weighs more than 5,000 lbs? this is a theoretical question, I know there are plenty of heavier vehicles but for a normal 3,000 lb car do I need a 9K lift?
I have same unit. Connect air hose to quick disconnect, close ball valve below catch tray & you pump it into your 5 gallon favorite container. Most auto facilities only take oil 5 gals at a time. This holds 20 gallons. I only need to go once in a blue moon.You connect your compressor to the tank and it comes out the hose? Where do you drain it to? Trying to learn some tricks!!
did you install it yourself?
I dont understand this statement "I got 2 of them and will use them for putting things on the lift when not in use.
I'm still trying to find some one to install a high lift. I really can not believe this is that hard to do or find some one that knows how to do it? I love when they say on the phone that they do allot of these and then when they get here. Oh wow I'll have to get back with you.![]()
LOL
