Cordless Drill / Impact Storage
Farmall 1066
Suburban Rockford, NE
Had a short stick of 3" PVC laying around. Made this rack in about an hour, with hole saw and Sawzall.
Not pretty, but works great.
Gear Wolf
Low cost solutions are just like what Tony the Tiger says: "They're Grrrrreat!"
600SL
Connecticut
I'm in the process of making one of those now. I have seen it here before and I like it.
wrench409
Over here....
Saw another thread on here about this.
Here is my storage system:
chillrich
This is my impact/drill storage
600SL
Connecticut
And here's mine.
I found that I needed both 4 " and 3" PVC. and I have some tools that may work well with 2".
My PVC tubes are all mounted with 2 screws to a 3/16" x 4" flat. The hangers from the pallet racks are made with 1/8" x 1.5" flat. I have 3/16" on order because the 1/8" is a bit flimsy.
Not sure if this is going to be too much interference at the work bench. I will have to try it out for a while. It may need to go under the bench but then I will need to bend down and I loose leg room.
Ainsley
Ontario, Canada
This inspired me to make one for my shop.
dutchgray
Dorset. England.
I would do this but we never seem to use 3" pipe at work and I'm not buying a length just for this. Good simple and cheap storage though.
maxpower_hd
Massachusetts
That's some funny stuff. I use the same system, at home anyway. lol I only have one cordless drill at home so I just hang it on the pegboard behind my bench and I have a drill and impact driver at work which have to live in one of the tool box drawers with the air tools so they won't walk away.
Grimly
Ireland
When I went to use the scrap pipe I had to make some cordless drill holders, as pictured in post #1, I found it was just a bit on the small side, so made do with what materials were to be had, like so...
It works well enough, but isn't as universal as the pipe idea - each hole is sized for a particular model of drill, whereas the pipes would have taken all sizes - at least in the cordless I have. I might use some 4" pipe for the air impact wrenches, as shown ^^^^ up there, somewhere. Problem is, there's no real supply of thick-walled pipe locally, and the 4" is actually 115mm - it will do, though.
