Black & Decker Workmate
Firebird 1
Maryland
I have one of the originals if I can figure out where it is I will measure for you. I got a new one about a year ago to use as a base for my small blasting cabinet, boy is it a pos compared to the old ones.
Dennis Leigh Henry
South Central, IN USA
I just got a Type 1 (the first version) which needs some attention:
Can someone with one in good shape measure the spring clip that retains the leg? I don't think the available plastic ones will work, and all four of mine are either broken or mashed.
I could probably figure out the radiuses by trial and error, but I'd rather not spend a ton of time futzing around if I can avoid it.
If that bench could talk.. I'll bet it would tell some tales... really neat patina.
McBrownie
Cleveland, OH
Dan, I think it will work. I've added pictures days later.
Co, I keep looking for one of those old originals, but no luck yet. I can't wait to see it cleaned up.
I don't think your reservation will work but it's an excellent idea. You CAN'T edit posts after...what is it? 30 minutes or so?
Sure you can; I've done it years later. My Garage Sale thread in For Sale is based on that.
EDIT: And to be sure it hadn't changed; I just updated a page of it...
taumac
Brooksville, Fl
+2 I've gone back and edited some of my beginning garage thread posts with no issues.
I think if anything it's probably best to quote your original post then restoration finished. If you edit it's most likely the people that follow thread won't see your edited post.
Honest Bob
Easton, PA
I love my workmate. Hell I almost use it more than my bench. Its a miter stand, paint booth, sanding, cleaning, and a bike stand (upsideown and situate the seat inbetween the jaws).
I got it for $10 at a yard sale. I'll be picking up another when the chance arrives.
Just clamp those curtain rods in there!
altersaddle
Victoria, BC
Haha, wow! At first I thought you had an unusual model, and couldn't figure out how it actually worked.
Then I saw the actual WorkMate underneath, working. Makes a lot more sense now...
I might rig up something like that for painting bicycle frames. Great work!
DIYorDIE
Me, too. I thought he was just posting a photo of a humorous "home made" take-off of the Workmate design until I read his caption about clamping the curtain rods in there.
John Bender
I made some "folding leg retainers" out of plywood.
My thought was that the metal tab on the leg would provide enough flex to move across the rigid retainer 'hump'...
Works pretty good.
Took some tweaking to make it hold...but none have broken yet...
Bike frame should be no problem, I had a full sized heavy drill press on one for several years without issue. I also put a table extender on another, and my 12" RAS was on that for several years.
TractorJeff
Elkhorn, WI
Didn't have time to read them all, but my Workmate is(??????). How does 20 years old sound? I bought it when I was apartment living and never let it go. It has the particle board tops but that's OK. I use it in the house still all the time!
kbeefy
Harington, Eastern Washington
I picked up an old school workmate for $20 at an estate sale, already used it many times.
Theres one at a local thrift shop for $5 missing a folding leg. Any source or anyone have parts?
McBrownie
Cleveland, OH
Depends on condition and how bad you need one. Compare to a new 425 and go from there...
Outlaw
Funny, but I never looked at new one. $110 from Amazon? Suddenly my $10 garage sale find that needed new feet and tops doesn't seem like such a good deal. Leaving the cast aluminum models out of the discussion, any idea how the new ones compare to models from the '80's or '90's?
Again it depends: What model? What did you replace the jaw/tops with? The current (back to the 80s/90s all steel workmates at least) have particle board and it doesn't take much to damage it. Definitely don't get it wet! And they don't hold a candle to the marine ply the old ones had...
Feet are cheap enough, and the plastic leg catches aren't expensive.
BTW, HD has the 425 under 100: http://www.homedepot.com/p/BLACK-DECKER-Workmate-425-Portable-Project-Center-and-Vise-WM425/202516382?cm_mmc=Shopping%7cG%7cBase%7cPLA%7cD25T%7cTools&gclid=CjwKEAjwpsGqBRCioKet--bp_QcSJADCtbsbujdQ5HsrkDm6luLZOaJB1xNokq9DmQ5Q2D_42bbYABoCh0Pw_wcB&gclsrc=aw.ds
The TV tray models I wouldn't keep for free. A proper WM is a stable work base...
41ratrod
Springfield Mo.
I got a early 80's one ,and still use it .Put it to work last week while sanding some cabinet doors and painting them. Saw one on CL $40 just like mine.
I don't need another one but if I did I would get it.
jd_1138
NE Ohio
The master carpenter building a house behind us has one. Looks like a cool device, wish I had one.
McBrownie
Cleveland, OH
I put on "apple ply" tops, which are pretty nice. Doesn't delaminate like the big box store plywood and can put up with moisture. Mine is a 350 and probably 20 years old. I'm glad I got one.
redmed
I have almost bought a B&D workmate for years. I remember having one in my cart once when my wife asked what would I use it for? I couldn't come up with a good answer, since I already have a Jawhorse, so I put it back. This Christmas Menards had some non B&D imitation workmates for $7. I was about to make some stands for some of my shop machines a scroll saw & drill press and thought these would make great stands so I bought 4. Two I use as stands and the other two are in my garage & workshop. I am surprised how much I use them. I should have bought a workmate years ago.
McBrownie
Cleveland, OH
Picked up this early Workmate on May 1 at a garage sale for $15. This one happens to be the Model 79-001 (Type 2) with the cast-aluminum risers. These were sold in the U.S. for a short time around 1976.
It underwent a bit of a restoration to get it back into shape. Here is process that I went through on this restoration:
1) Complete disassembly
2) Regluing delaminations in the original plywood top
3) Sanding down of the plywood top
4) Rebuilding the finish on the plywood top using multiple coats of boiled linseed oil
5) Sanding out rusted areas on steel table base
6) Priming and repainting of steel table base
7) Reassembly
Hopefully now it is ready to go another 40 years.
First of all, $15 gets you a "You ****". But wow, what a transformation! Very nice work and I would say that it is definitely ready for another 40 years. :thumbup:
easyrider13
Sarasota, FL
I screwed up and left my workmate outside over the winter ruining the wood jaws.
On a B&D parts site the cost of the replacements was very high.
Is there a site (or other seller) you can recommend to buy these for a more affordable price?
y'sguy
Tulsa, Oklahoma
I didn't think you could buy the replacement jaws? But certainly you could make up some new ones. Seems pretty easy to me. And you could use a better quality of plywood possibly. And don't leave it outside! :)
Blue Frog
Lynn Haven, FL
I picked up a very nice, but dusty one, off C/L today - it's a type 4 with the original label on top. I'll post pictures tonight.
Blue
taumac
Brooksville, Fl
Make a set from plywood, MDF or I wanna try composite deck boards.
These are the older jaws the Aluminum frame model has; Note it's hi-grade ply and they added a secondary piece to make the jaw face thicker. I like this feature, adn recoment better materials for the jaw...
If you can source it, I bet bamboo would make killer WM jaws...
McBrownie
Cleveland, OH
This is what I used. It's a 13-ply no-void plywood. Get a 24" x 24" piece and have some leftover. A 20mm Forster bit is needed if you are going to use the original dogs. Or, buy 3/4" ones from Rockler and drill 3/4 holes.
http://www.appleply.com/
IPACA9
Independence, Mo
I found a local guy that has a pair of these that he will sell for 70 bucks. They are the workmate 425s. I already have one that I think is an original. Very heavy. Is there any special site that tells about the differences of these?216b0b6b61997dd18959d9f3b7d5a880.jpg
That would be a good choice! did you double the faces?
Not sure what I'm going to do when I weed down to fewer WM's.. I have a bunch of tools setup for clamping in the single thickness jaws. Maybe I keep one of the three 200's for a dedicated power tool stand...
If I suddenly had unlimited space I'd make a bigger bench and embed the hobby or table top model into the bench top to do the job...
425 should be current production I think
IIR, that has a 3 piece top and you can get a wider opening by removing the middle one, and the clamping jaw should have the "til up" feature so you can clamp down on the top. nice to have.
for $70 in that condition that's a deal! :thumbup:
It pretty much is! :D Not much of a story: I was at an estate sale, it was actually sitting outside the garage in the entry area before the front door. I happened to step outside the side garage door, saw it, and asked if it was for sale. "Sure, hows $5 sound?" :evil:
Needless to say, I simply picked it up and set it in my pile.
It's missing the screw-on feet for the "short" stance, but those are just fairly std screw in feet available at any hardware store. Or maybe you are expected to use the ones on the extendable legs... :dunno: Other than that, it's complete and really doesn't look like it's ever been used. :pimpflash
