It's as good or better than any new one of the same price.
If you need one, that one will work just fine for you.
But:
Unless you have a real and often use for it, I'd pass. They take up more room than it appears in that picture.
I have a $90 ryobi counter top unit. I haven't used the floor press in years.
24 " counter, I can slide the ryobi back against the wall and still have plenty of space.
true, I have a (I think) its a 17-900 delta, about 15 years old, Floor model, 12 speed, nice drill press, but I don't find myself using it all that often.
Its nice though if you have something tall to drill.
But they say too, you can cut a hole in your bench, and slide the bench out, put the DP up to the wall, and push the bench back in.
Really, your right about the floor space, but then there is the other side of the coin,
that a bench model takes up bench space, So, l guess there is always a trade off.
I just got an old "Cone head" today, its smaller than l thought it was (from the CL picture)
but, l had to have it................
Will be posting pictures in the "garage sale" thread later, as it's still in the car. It is a heavy little ****** for it's size though.
Actually i am going to sell my 17-900 delta floor model drill press.
Probably kick my self a month after, I'll need the height for something then.
EDIT,
if you going to be drilling a lot of metal, you may want to consider building a jack shaft speed reduction set up for the atlas.
Why not offer $200.00 for the altas.
I think it's worth it,.
