ryan t
Bristol, Va.
Oil change and tire rotation on my commuter car, oil change in my truck, oil change in the corvette, cleaned the deck on the mower and sharpened the blades, put a vanity for the bathroom together, cleaned up, swept the garage out.
buzz4041
South Texas
Doing trim work and door tracks and another coat of paint on my cabinet. Pulled off the bedroom door and gave it a fresh coat of paint also.
Dennis Leigh Henry
South Central, IN USA
Went to an auction with my eyes on a 36" stop shear / Pexto and a box and pan brake same size and maker. Get there, plenty of time to see what's up.. heck.. going to stick around, lots of shop stuff.. then the auctioneer.. "I'm going to sell the real estate first (hour delay) then get to the tools and then to the vehicles / tractors / trailers.... It should be raining by 3:00pm,, and we should be inside by then.. so ....to wait around for 5 hours to bid on something I might win... .nah.... we went home... :(
MrAperture
Montreal, Qc
something's wrong with this truck, it's all broken and lying on the ground.....
Now you can fix his suspension...:lol_hitti
Tommy
You guys are so funny, last time I laugh so hard I fell off my dinosaure [emoji19]
Chaznsc
SC
Not very exciting but I finally built a mount for my electric motor for my canoe.
bmxdad
Puyallup, WA
Tore an old McCullough MAC 3214 chainsaw apart to put a new primer bub on it. What a pain ... I will have to replace all the lines they are so rotted out, so I'll need to pull the fuel tank. But wait, you need to tear the whole thing apart. No wonder they cost so much to repair.
Lippyp
Shropshire, UK
Just a quick visit to solder together a speaker cable for the PA amp that was donated to our Scout group. Finally got all the cables together to test it out, boy the thing is loud, will make our Carnival float in september rock. Might need to keep an eye out on ebay for a second speaker though, the current one (12" woofer and horn tweeter) could do with some help!
jpickar
These tracks were out around the shop this morning:
Our bears are out too. Griz and blacks. BUT we have no snow!! It is sunny and warm here today! But we will have a bear problem this fall.
John
justanengineer
Motor City
A few small projects including making SWMBO a couple new feet for her couch. Whoever decided the originals should be injection molded plastic ~1/16" thick should be shot.
topop101
NW Missouri
I have two Dake 001 arbor presses, one of which was missing the round plate. I fabricated a new one out of a 1/2" steel plate strip that was 4" wide. The factory one was cast iron and had been broken and repaired. I believe part of the reason it broke was the 3 largest holes were next to each other making it very thin in between them. So instead of having holes in a 9/16, 3/4, 7/8, 15/16 and 1" pattern I went 9/16, 3/4, 7/8, 3/8, 1". I also made a square plate for when you don't want the "holey" plate for more surface area with some jobs. I tapped the plates for a 3/8" bolt which was cut off after it was tightened down. The blue on the plate for scribing the lines is just a Sharpie marker.
Well that's just cool. I really like the sharpie idea. The reason I ask how many hole positions yours had I was already considering making two plates to reduce the amount of holes per plate. I also like the idea of a square plate. Thanks so much for the impute. I'd like to see a photo some time of your presses .
LS6 Tommy
Northern NJ
We had cleanup day at the lake yesterday, so I loaded up the leaf blowers, line trimmer, chainsaw and rakes and went at it.
After running 4 tanks of gas through Dad's old walk behind leaf blower, I figured I should do a PM. It got an oil change, carb cleaning, new air filter and spark plug. I couldn't stand the surface rust, so I took the handle off and polished the plating. Of course I couldn't stop there, so I took the engine off, cleaned everything and reassembled it. Looks better than when Dad gave it to me 18 years ago. The old beast has to be at least 35 years old and it still runs like new.
Tommy
niget2002
Josephine, TX
I worked on my quadcopter. I got into rc helicopters last year and have spending a fair amount of time in the shop because of them.
Shady Oaks Garage
Smyrna, SC
Well I went to the shop, open the door and there it was a blacksnake the last I seen of it was going in the insulation the only part not covered by wood just my luck. I guess a trip to tractor supply tomorrow for some Snake-away
glad its nice weather I'll be working outside the door
buzz4041
South Texas
More paint on cabinets and painted another door for inside the house. Cooked up burgers for my mom, sister, wife and son. Great day to day the least.
GTA Matt
Zebulon, NC
Started on saturday morning, lot of cleaning and sanding, cleaning and sanding, then more sanding, priming, more sanding, and finally paint.
tinbender 66
Western Washington State
Got the mower out, mowed the grass, burned the burnable stuff in the pantry, finished trimming the wheel well lips on the Nova so the tires don't rub on hard rights or lefts. Success on all fronts. Good day!
polexican23
burbs-Illinois
fixed the busted water line in the garage, behind the drywall I just put up 4 months ago. ARRRRGGGG.
But the sharkbite (proline is Lowes knockoff brand) coupling worked with no soldering of copper. Never could sort that out properly.
NUTTSGT
Northern Central Ohio
Ever skim through a post and be like :headscrat
I had to go back and read Buzz's post a second time. I thought it said something else.
What I thougt I read Cooked up fingers
:spit:
the gypsy
Montreal, Quebec, Canada
:spit:
Yes it has happened to me a few times. So not to feel stupid I go back many posts to read how the thread progressed. Should have taken the time to read it properly the first time. I would have waisted less time. we all make mistakes. LOL
thorgy
Just got done with my welding cart. I have had the welder for 4 years and never had time to build one. After knocking over the gas cylinder and braking the one hundred dollar regulator, I decided it was time.
welder4956
Birmingham, AL USA
Nice work. I used to have a hand truck from HF that looked a lot like your cart. Good job repurposing.:thumbup:
LS6 Tommy
Northern NJ
Did you use tin foil on it or.....?
Never heard of that. I went to my old standby- 0000 steel wool & a little WD-40 for the rust removal. Wiped down with brake clean and then a light polish with Simichrome. It's not perfect, but it looks great compared to the brown handles it had before. If I was smart, I would have done before and after photos.
Tommy
dcmus
Ardmore, Ok
Not sure I understand Tapatalk yet. Pulled wire for outlets today.
mounted sub panel
Now I need a lift to hang lights but it's gradually coming together.
NUTTSGT
Not sure I understand Tapatalk yet. Pulled wire for outlets today. mounted sub panel
I'm guessing that picture needs rotated ?
EDIT: nevermind, after seeing the floor after I scrolled over, yes it is a sideways picture.
Me, fabbed up some shelf and O/H door brackets.
k-os
WI
Got a coworkers ZX11 running after it had been sitting for 5+ years.
Also started painting some trim for the garage.
MrAperture
Montreal, Qc
My friend's has a landscaping business and asked me to fix both rear fenders on his Worktruck. I'v cut and replaced the sheet metal on both side, welded and grinded. Tomorow I'll have 3 inches of spot welding left and then grind the weldings smooth and apply putty.
Also cop a new Neiko Air punch, if you do body work and you dont have one, you are missing out big time.
quick60
Virginia
Changed the oil in my wife's van and built a 4' x 4' cedar planter box. Did not calculate enough dirt properly so did not plant all the peppers I bought. Will finish on Wednesday.
Got the 67 GMC inspected in someone elses garage.
