kctyphoon
Crescent 9" pro series compound action lineman cutting pliers - $9 EDIT: now $6
these are one of my favorite pair of lineman pliers, along with matching cutters. they give you the best combination of every available feature... cushion grips / locking, spring loaded handles / compound cutting action / dual tooth designed jaw / lightweight design / handle detent stops handles at comfortable distance for one handed use AND handles can be manually opened to 180 degrees for 2 handed use.. this give you BOTH compound cutting action and wide jaw openings. (despite what reviews say - those people dont realize you can pull the handles past the detent to open the jaws wider) these are nothing like the similar styled Dewalt verison, i have those too and they are horrible. they barely open, and the cutting edges are much softer. both tips of my diagonal cutters broke, and the cutting edge of the pliers are chipped after minimal use.
this is a great pair of pliers for people that work with gloves.. there is no need to position you fingers and hands like you would with regular lineman pliers. the spring loaded handles allow you to keep all your fingers on the outsides of the handles, and let you apply full force when cutting without having to constantly re-position your hands. i keep these pliers and cutters in my tool try even when using my Knipex stuff. i may even wind up going back to these after im done experimenting with all the other sets ive recently bought.
Crescent PS20509C Pro Series Linesman Compound Action Cutting Pliers, 9-Inch https://www.amazon.com/dp/B000LY8LFQ/?tag=atomicindus08-20
