topop101
Is that a weld all the way around the slide?
it's grease.
You ever work on one of these balane
Or any one else have info on JET vise's
Ok I got a a crazy amount of stuff today for $170.
Parker 974 to flip
Heinrich 6"to flip
Heinrich 4" for my drill press
Ton of indicators, parallels, transfer punches, bits, taps, small machinists vises, micrometer, bunch of bins, and the toolbox that all the drill bits are in. Lots to sort thru and figure out what's what. Most will be going on eBay.
ALL: if that 8 inch Parker needs new jaws Kevin might still have the plans for them in his files that i think he sold for more than the seller is asking for the vise. just saying if you need to work on a Parker it ain't cheap, but they are good vises. here's what a $2500 Parker 958 looks like with Kevin's new jaws on it.
Speaking as someone who has been burned before, I completely agree. As much as I would like a Parker Swivel Jaw, I'm steering clear of this one on eBay. It ends today and is currently at about $80 with shipping included, but a look at the jaws spells trouble. They look worn and welded in place.
http://www.ebay.com/itm/PARKER-HEAV...277?pt=LH_DefaultDomain_0&hash=item3f4cc0959d
Bet the reserve is over $100. Looks like the seller did his best to hide the welded jaw insert on the swivel jaw in the pics, and no mention of it in the ad.
FMC and Sbose, since those are cast in numbers, and the plate would have to be stamped out and installed each vise, (you can see the pop rivets holding to the pattern) I doubt they are serial no's; it would be too expensive to replace the plate each time for each casting.
Probably either a mold/pattern number, or possibly a date code or Lot code for a batch of castings.
BC: while you have that 5197 out before you hire the Sherpas to haul it back into the dark rust free corner can you get me pictures and measurements of the vise nut (spindle). I appreciate the time you took and costs and energy involved to measure the holder, but it's my vise nut that is missing the screw and piece behind the slot and it's also busted in half.
here' the vise nut (spindle) of my 5196 to show what i'm asking about.
thank you very much.
Is there a chance he mated an older rear jaw on a newer vise? Did every parker have replaceable jaws? They could be welded but if not, it could be an early non-removeable jaw casting
Ive seen some Frakenstein vises before that its a possibility that he made 1 functioning vise out of 2 broken ones
Just my .02
DIF, I wonder if your 5197 vise nut may be the same part as my 5191 nut. The reason is that when I look at my 4" 5191 the handle seems really big, much bigger than the one on my 3.5 " 5195. So maybe the used the same handles/vise nuts on multiple sizes.
Just in case, here are a few shots of my 5191 vise nut. It has a number stamped on it, that I read as a "W" with a dash in the middle, like an "A". Below it is "5V7814". Perhaps you vise nut has a number on it?
Let me know if it matches and we can look it over more closely.
BC: it might be time for you to start selling or sharing some of your duplicate 519x's because not sure anybody else has all of them to ask to do this. or if you want to be popular and keep us informed keep buying, restoring and holding on to them because they are like gold.![]()
The biggest "vise" produced was the Blackiston patented "Pittsburgh Railroad Vise" that was made for train yards to work on train axles. Not exactly your everyday equipment for around the house.
Maybe so, but I bet if someone gave you one, you would make some room for it.
