Astro Pneumatic Tool Company
A
Astro_Pneumatic_Tools
South El Monte
I'm sure they're just fine. Just wanted to know if anyone here has put their hands on them first hand. :thumbup:
PM me a size you might use and I'll send you one to see how you like it.
3/4", 7/8”, 1-1/8”, 1-7/16” and 1-13/16”
And here's your 1st hand:bounce:
__________________
Chris P.
Product Manager
Phone# (800)-221-9705
image.php
gipraw
Cypress, TX
Hey gipraw,
Our Sugg. List is about $250.
A few distributors have purchased it already so it should be appearing online any day now.
The speed settings are on a wheel and is adjustable.
Please see the Product Info Sheet (http://www.astrotools.com/pdf_info/3058.pdf)
Thanks . I see the wheel, but everything I see says it has six settings. My question is are those the only six speeds, or is it a true variable speed, and those are just OPM listings at each of the 6 detents?
Can I run it @ 4.5 or do I have to choose 4 or 5 .
I am in market for an additional DA, so I want to add this to the list of pieces I am considering.
A
South El Monte
You are exactly correct, there are 6 detents with those preset speeds. The OPM are essentially infinitely adjustable in between the lowest and highest setting. As a matter of fact, I spent most of my time in between two settings when cutting as it worked best at that setting.
__________________
Chris P.
Product Manager
gipraw
Cypress, TX
__________________
Chris P.
Product Manager
Thanks Chris!
ADSR
__________________
Chris P.
Product Manager
image.php
Holy smokes! Thank you very much! LOL, i need to find out what size my 06 F350 uses!!
Will be in touch!:thumbup:
A
South El Monte
I know we're low or out of one size in parts and I just saw you're in BC, CA. So i'm not sure if we need to ship to the boarder or what.
I can ask customer service.
__________________
Chris P.
Product Manager
A
South El Monte
Astro's new 326P Heavy Duty 6" Quick-Change Random Orbit PSA Palm Sander - 3/16" Stroke is constructed with a quick-change front mounted locking button that requires no tools to quickly change out backing pads. This tool has an extremely durable design with high quality machined components, and ensures a professional finish due to the 3/16" random orbit. This tool provides high power and rapid material removal with low air consumption, and includes a 6" Polyurethane PSA backing pad. Both 5" and 6" backing pads can be used with this sander. The 326P will be in stock Mid June, so make sure to contact us for a distributor near you!
http://www.astrotools.com/index.php...random-orbit-psa-palm-sander-3-16-stroke.html
(800) 221-9705
[email protected]
A
South El Monte
Because trying to break things is part of my job description
<iframe width="560" height="315" src="https://www.youtube.com/embed/Vq7Z6_s8CR4" frameborder="0" allowfullscreen></iframe>
__________________
Chris P.
Product Manager
image.php
A
South El Monte
Farmall450
Marengo, Illinois
CobraChevelle
Wisconsin
I like the light, but don't like the idea you need to buy a hook for it. Either the engineers forgot to add that or trying to make more $ selling it separate
A
South El Monte
It's surprisingly difficult to incorporate a hook into a 1/2" thick light, especially when people have come to accept that you can drive over the thing.
If the design originally featured a hook and was altogether treated a little more fragile because of this it wouldn't be a problem, but for over a year we've been trying to agree on a design with an incorporated hook and it basically requires a different light design altogether.
That said, anyone who wants a hook - send me a pm.
__________________
Chris P.
Product Manager
image.php
K-Dog
Millersville Maryland
scooternut
Pittsburgh, PA
I have been using your pencil grinder for a few years, mostly in knife making and I really like it. Thank you for an excellent product and at a great price.
A
South El Monte
Take a look at Astro's brand new 7790 Portable Tire Compressor for Use With 12V Pocket Jump Starter!
2417 Seaman Ave., South El Monte, CA 91733
(800) 221-9705
Tel. 626-228-3170 | Fax. 626-228-3124
[email protected]
https://scontent.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/11429716_10153332957717383_69568564454817257_n.jpg?oh=19f59033170030c97e0d1b5245bb1ed9&oe=55F4EC6B
A
South El Monte
Hey guys, this is the Astro 9512 Clamping Valve Core Removal Tool for tire valve cores and HVAC/Industrial Schrader valves. There's not a lot of tools on the market that hold onto the core once it's removed so it doesn't shoot across the shop during removal and installs or just making it more handy to locate when you need it - hopefully those looking for a tool like this have an easier time finding it and find it at an affordable price now.
__________________
Chris P.
Product Manager
image.php
2ndGearRubber
Pittsburgh
Those Tie-rod wrenches are key.
What's your feeling on the quality of the ball joint adapters? I need more, and OTC is always expensive.
A
South El Monte
Check out Astro's brand new 78613 One-Person Brake Bleeding Wrench Kit w/ Check Valve, which is ideal for brake bleeding without removing the wheels and/or raising the vehicle. It allows the user to speed bleed brakes from the driver's seat without monitoring the bleeders. The one-way check valve eliminates drip since the tool will not bleed without being pumped and also prevents air or old fluid from entering the brake system. This kit includes 3 different wrench sizes (8mm, 10mm, and 11mm), along with a 4ft hose. The wrenches seal to the bleeder valve, and tighten or loosen the valves without losing the airtight seal. The new 78613 will be available Early August, so make sure to contact us for a distributor near you!
http://www.astrotools.com/index.php/one-person-brake-bleeding-wrench-kit-w-check-valve.html
(800) 221-9705
[email protected]
