The hard to find Craftsman Speeder Ratchet (model #4408) ! Congratulations !
Those were only sold between 1960 and 1963. They can sell anywhere between $50 - $150 on ebay. I've only seen one out in the wild (the one I restored). The other one I have was purchased for stooopid money in a fit of auction insanity. Most have a blue handle, only a few that I've seen in pictures on the internet have the black handle.
,i was looking for it since long time and the price was cheaper than black handle
And now - The Failure. (dun-dun-dun)
I picked up this Williams S-51 1/2dr ratchet last October. The action on it was rough and skipped a little, so I figured that it needed a good cleaning. The holes on the collar were buggered and I couldn't get it to unscrew without making the damage worse. I even left it soaking in Marvel Mystery oil for a few months. When that didn't work I soaked it in PB Blaster for a few more months. Still no luck.
This week I was able to use the Park SPA-1 pin spanner on it. At first it kept slipping out of the holes, so I rigged up a clamp to keep it in place. I held the ratchet in a vise and slipped a large washer and nut over the anvil to hold the spanner. I held it all in place with a c-clamp. A few taps with a rubber mallet on the spanner and the collar was finally free. That's the last of the good news.
As I took the ratchet apart, I found that the pawl was broken. Fortunately, the way it broke, the pin holding it in would keep it usable so I kept going. However, upon inspecting the teeth on the anvil, I found severely worn teeth, and 3 broken ones. This ratchet has seen a harder life than it first appeared. It seems that this one is destined to be a donor.![]()
,any idea
Need help with bonney ratchet disassembly. Using a flat screwdriver I can push the retaining ring but can't get it pulled apart any advise?
after removing the retaining ring ,try to put the slectotr in netural postion the apply some presuure to take the gear out .i hope that will work
I found that sometimes the pin that holds it together sometimes catches in the groove, keeping the selector from spinning 360° when the anvil is removed, as it should. Try moving the pin back and forth until the selector spins around.
If that doesn't work - pull the pin, spin the selector 180° with the pawl in the same position, then put the pin back in.
EDIT - I just took another look at your pictures. The pawl and selector are fine, it's just that the spring/ball are holding the teeth on the pawl in such a way that it won't release and allow the pawl to spin. You're going to have to find a way to take it apart, or get the tension off the pawl so that the ball will release it.
Good luck, this may not be an easy puzzle to solve.
What do you use for a punch to seal the ball bearing back in the ratchet drive?Hi PJ,
Welcome to the forum.
Yes the ball bearing can be replaced. If you go to any (well stocked) hardware store with hardware assortment bins (Hillman or Mid-West Fastener) they should have a drawer with loose ball bearings of various sizes. It's just a matter of finding the one that fits the hole that the spring sits in. You want the ball to be tight, but loose enough so that it won't bind in the hole. Buy one or two extras in case you loose one trying to install it.
Use a good lube when you put the ratchet back together. I use SuperLube (available at Harbor Freight and many local hardware stores).
Good Luck.
I got it open and the guts are cracked on the one direction action. Sad to see guess it will be a parts ratchet.Yeah, I've got one. Sliding block pawl. Very stout, very tough. Circular snap ring comes out like the S-K roundheads.
Hey all! Old thread, but hopefully still active. Recently acquired a Craftsman circle H 1/2" drive ratchet(10-45 S), and it appears that the little spring inside is broken. Are there replacement parts available anywhere? Thanks for the help!
Most of the time one can "make" a suitable spring for a ratchet (if that's the only issue). I've fixed alot of ratchets with coil springs from discarded writing pens.
Worst comes to worst you can wind some thin steel wire around the appropriate sized finishing nail and make a spring decent enough to work an old ratchet.
Well, Ed, for your debut effort, you certainly couldn't have picked a much rarer or more iconic specimen than a V-selector Craftsman spinner to put back into service! Well-played.This my first ratchet rebuild...
Hey, how did you disassemble the F670? I cannot get the faceplate to budgeRe: Show us Your Vintage ratchet before and after restoration!!!!!
List of current projects:
L715
F70n
Sr710
F749
F670
F720
I710
Tml836
Tm70a
Mv71
Gf720
Fk720a
Gear sets removed and bodies all hit the wire wheel at this point, just gotta clean the internals and start cleaning, etc.
