They carry that at Harbor Freight. Usually goes on sale for @$4.00 once or twice a year. Used it twice and it does what it is supposed to do just fine.
the one i had broke almost instantly... to be fair it was an extra thick gear oil milkshake
I've used this one from HF a few times with good results. I would opt for it over the red plastic siphon pump. http://www.harborfreight.com/oil-suction-gun-95468.html
Just remove the cap, fill it up, then pump it into the trans or diff. Repeat as many times as needed. It holds approximately half a quart.
For only a little more you can get a real tool that will actually **** as well as push so why not?
http://www.amazon.com/dp/B0002SRJCM/?tag=atomicindus08-20
Now I've heard that since I bought mine that Lincoln has moved some production to India; I hope that the current products are as good as mine.
I purchased that Lincoln you have linked about a year ago. It is made in India. It is just as cheap and crummy as the Performance Tool branded ones for $10 or whatever. Junk. It is not a real tool in my book.
