NUTTSGT
Northern Central Ohio
While I was mowing yesterday, one of the handle mounts on the deck broke lose. I fixed the other side last year or the year before and knew it was a matter of time before this side broke also.
Not the greatest picture, it appears the camera focused on the tire. You can where I had to try to build it up as it kept blowing out around the thinning radius at the back of the deck.
The right side was thin also but not as bad as the back. I think I'm going to have to look for a new deck in the near future. Luckily, my mower being an MTD, are built in Shelby about 11 miles away and there a surplus store that sell tons of mower parts.
This was from a few weeks ago when I changed the fuel filter on the Samurai. (I already had to take the top of the carb and pick out a bunch of "floaters" that were making it run rough at times, and a couple of times when it flat "ran out of gas" but wasn't...
A good reason to have a good fuel filter! :wtf:
Mixed in all that crud is a scrap of red paint, since the PO didn't mask off the fuel nozzle...
Not sure where they bought gas, but I'm glad I got the car from about an hour out of my town..
Doogbert1
Massachusetts
Started outdoor fire pit table. I angled it to fit properly between two adirondack chairs. Will finish webbing and attach cup holders.
Dennis Leigh Henry
South Central, IN USA
toddacimer
Oshkosh, Wi
Made some progress on my truck b0x couch
srmofo
SW ohio
Whipped up a pry bar rack with my swag press brake kit. First project with it despite the fact Ive had for a year. Then I hung it on a tool cabinet Ive been working on. Next up is all the racks for my clamps that I am going to hang on the back of the cabinet.
rartuin270
Fort Wayne, IN, USA
I put up my spacers for another sheet of pegboard and hung a sheet. Hung the first cabinet by myself. Finished up a stand for my band saw that I started yesterday. Fairly productive day! :rocker:
sprntpshr
Southern Ontario
Sorted thru a trailer load of furniture today, chairs, desks, horizontal file cabinets, office supplies and an old phone system. It was a "help a friend deal" when they got stuck with the task of clearing out a lawyers office.
Some of it will be useful, heavy desks might work out as a nice work/electronics bench, 2 file cabinets sold off already and covered costs, Mrs Sprntpshr acquired the office microwave.
Maxi Max found a new perch...
sprntpshr
Southern Ontario
I got to clean things up while sweating my *** of. Last I checked, I am in Maine and it isn't even June. Why does it feel like August??????? I hope to get something photo worthy done this weekend.
Waited till Sunday to unload the trailer of prizes....it was 40 degrees cooler than Saturday and had to keep the door closed to stay warm:dunno:
LCD
Pennsylvania
Where can I see and learn about the car a little more?
I live in Pennsylvania and it is kept in my garage. Where are you and what do you want to know.
It is a 1953 Dodge truck made for the US Army and is known by them as an M37
iceman510
Finally started organizing the garage (moved here last fall). Painted the walls in one corner white (changing from a tan-ish beigy color) and started assembling a 8' by 32" shelving unit for car parts storage.
Also working on the stuff needed to wire up my compressor.
polexican23
burbs-Illinois
My ADD kicked in on Sunday. Bounced between 5 projects in and out of the garage. Each month it appears to get worse and hard to focus on one project at a time.
Vegaman_Dan
Pacific, WA
Sunday was a busy day.
On Saturday I picked up a used range from a used appliance shop for $100. They had cleaned and tested units for $170, which seemed silly when you can get them for free or super cheap on Craigslist. For $100, I got one that was filthy but they said if anything didn't work, they'd give me parts free to get it running.
Took it home, soaked it with oven cleaner and left it in the sun. Sprayed it again that night, left it overnight. Sunday morning I attacked with a pressure washer and was amazed how well it cleaned up. It's cleaner than the oven in my kitchen! Hmm, nah, pressure washer probably isn't a good idea inside. Drat!
Added a longer cord, put on casters on the front and larger wheels in the back so I can wheel this like a handtruck through the yards to the storage area when not in use. I wired it up to use the same outlet as the welder when not in use and tested it-
NOTHING.
Well damn. Looked up wiring schematics to see what I did wrong, then thought I better turn off the circuit breaker before I go screwing around and- wait, it's already off? Oh yeah, I keep the 220v circuit off unless I'm actively using it. D'OH! Turned it on and the unit worked perfectly. Took it up to full heat without any issues. Cool. Powder coating adventure time soon.
Once that was done, I assembled the soda blaster and attacked the Spitfire tub.
It is a messy process, and wearing a set of painter coveralls, a full hood, mask, respirator, and ear plugs is necessary to keep this stuff under control. You're blasting all the cracks and crevices of the car body, not YOUR cracks and crevices!
It won't remove rust or scale. That's not the intent. It will remove underbody coatings, paint, and finishes. It won't harm rubber, glass, or fiberglass. It's not fast, but it's quicker than mechanical or chemical methods. It's not that loud either.
The finish it gives is baby **** smooth and wonderful. You'll still need to rinse off all the material before you go to work the metal since it leaves a coating, but I have to say I'm impressed.
I went back over areas I had previously done with mechanical means to get in all the seams and brackets that I would have had no chance with other approaches.
I ran out of soda before I could get the rest of the firewall done. This was a 50 pound bag and you go through a lot of it. I used what Harbor Freight had because it was available. At $40 a bag, it wasn't cheap and this is not a cost effective means of stripping at that price. I found that sodium bicarbonate is also used for livestock as some sort of digestive aid typically for goats, and my local farm supply has it for $15-20 for a 50 pound bag, which is less than half the cost. That makes it affordable. Unfortunately they were sold out, so ended my day. I have several bags on order.
ramairthree
I pulled up 315 GarageTrac Tiles to lay a new pattern and go from a 2 car to a three car gagage.
Then the 145 new GarageTrac tiles that came UPS today did not match because they ran them in a mirror image mold or something. My order was right. What I got was not.
Then I got on the phone and found out they had when I ordered but did not send the right ones and there are no more they have but they will double check and call back tomorrow.
Then I spent an hour and half verify every single tile they sent me is the mirror image of the pattern I have and got nothing done and wasted all my free time I had today before starting a string of 12 hour shifts.
It was great.
zmotorsports
Northern Utah
Last night I installed my new BFG KO2's on my Jeep, then removed my hard top, cleaned the top and installed my soft top for the summer. I am a bit late this year installing my soft top but the weather has been wet for the past month and I didn't want my soft top on for our trip to Texas a couple weeks ago.
Tonight she gets a good detailing to remove the red Texas mud from her finally after getting caught up on customer jobs in the shop.:D
Mike.
2nrguy
Ground down the head of a weed whacker because I forgot to put the plastic cap back on. Don't gave any thinner line so it's off to Sears in the morning.
Hpozzuoli
Rhode Island
I cleared some land at the new place and began making my shed. It's going to be 12x24. That's as big as I could go and still use it the way I want to. It's been rainy so I haven't been out there for a few days. I have 15 posts supporting it. I am doing the joists in 2x6pt. I will use 2x4 for the rest.
Bib Overalls
Jonesboro, Arkansas
Piddled with the Buick 401 Nailhead I am taking down. Yesterday I found out why it had been parked. The oil pump failed in a rather spectacular way. Cam and lifters also shot. Remarkably little wear in the cylinders. No surprises today. Just more of that pre-detergent oil residue. When you get it on you it is like having a tattoo.
Steevo
43.49600, -112.04300
Today I worked on some modifications to a garden tractor dash. I am converting an older tractor to have power steering from a more recent tractor.
Cut out the original steering column section:
And fabricated a new, wider column to accommodate the P/S valve:
patrickn
State of Confussion, somewhere in Indiana
Continued cleaning and preparing the Bronco's interior for painting. Also did some rewiring since I have the dash out. I have to go slowly because I just had another procedure done on my neck, so its work a few minutes then sit back (which is working out good because I can find more to do when I am looking it over lol).
zcar751
Knoxville, TN
Worked on the Puma's brakes some more. I found the rear wheel cylinders were not functioning properly, hell they were frozen solid. I guess the set to long. This is probably why the rear circuit of the master cylinder was blown out. :headscrat So I pulled the master cylinder out and the rear brakes down so I can take the parts with me to parts store. Looks like another parts run at lunch tomorrow.:3gears:
View media item 51100View media item 51101
buzz4041
South Texas
Hung a few sins up in the lift area and on the new cabinet ends. Got a new paper towel holder also.
kaymccampbell
Upstate New York
Finally finished the metal storage rack. Got it hung and put all my stock/scraps in it. So nice not to be stubbing my toes on stuff on the floor or having sheet stock decide to escape and slide into my ankle.
Dennis Leigh Henry
Got the luggage all ready to receive the new wheel.. hopefully Mon/Tues...
Got the wheels ($20 w/ shipping).. Back like new and ready to roll...
Shout out to Volcrew who gave me the lead to OhioTravelBag.com, who expeditiously sent the replacement wheels so I could get the luggage repaired prior to an upcoming trip overseas.. (excellent customer service and they handle a large line of leather working and related tools).:thumbup:
rmalkow2
Brighton, MI
Got any pics you can post. I'm trying to decide how to do something in my garage to stop the same toe stubbing situation.
kaymccampbell
Upstate New York
As soon as I get my laptop back, hopefully this weekend, I'll post some pics. I've been running on a Nook for quite a while. Works pretty good, but doesn't pull pictures from the camera.
Back on topic. Cleaned up the last of the **** on the floor from the last few month's renovations. Pulled the Caravan in for brakes and decided to make it an early evening. More fun in the land of the half-assed tomorrow.
Steevo
Reamed out an axle pivot for a garden tractor, pressed in some bronze bushings, then reamed those to fit the shaft.
Pressed in new spindle bushings in the axle ends:
Un-boxed the new engine that arrived via Fed-EX:
This project is about to go full steam ahead.
dcmus
Ardmore, Ok
How did you drive that reamer? I've followed your thread and it's awesome. I started down the machining road 3.5 years ago and have SOMUCH to learn.
Steevo
These are some old adjustable reamers that I acquired in a lathe purchase some years ago.
I have been using them by hand, turning them primarily with an adjustable wrench.
Because the drive ends are not all one size, there isn't one tools that will fit them all.
The smallest one is 1/2" square, so I can turn it with this:
Ruger_556
I like 8 point sockets for turning reamers, the adjustable works okay but it's not quite as handy...
rharman
SoCal
<pic removed>
<pic removed>
<pic removed>
Why do I get the feeling that you are really enjoying this retirement thing?? :drool:
ZRX61
Solar Blight Valley, SoCal
New front tire on the Kaw1100. Had the local H*nda dealer swap the tire & my roomies dog gave the place it's seal of approval by shitting on the floor after the shop owner got it all excited.
Dog is sleeping, bike is back together & ready for the weekend hoonage
