I have the Cornwell version. It's pretty nice. I think the part number is TR42.
I have the cornwell as well
That flexhead SK blows my fixed handle wright out of the water.
Heres a couple of pictures of the wright 3/8 in a 1/4 body that I got from epstiens. Have used it a couple of times. works very well in confined spaces. This was my first Wright ratchet and I was impressed.![]()
Anyone know if this:
http://buy1.snapon.com/catalog/item...682972&supersede=&store=snapon-store&tool=all
will fit in a TX72?
(from Bart Simpsons cut and paste)
Edit: Found this:
http://www.garagejournal.com/forum/showthread.php?t=182887
SK part number for the kit is 45173-2
Well looks like I blew it. I bought the conversion kit on ebay that says it's for a 936 ratchet. When I got home from work and dug out my old ratchet looks like it's a 831 and the kit doesn't fit. I don't want to waste anymore money can anyone give me the williams flexhead ratchet part # that this kit fits.
No screw going through the Williams USA ratchet selector. Didn't see one on Amazon with that in the picture.I was was going to order the same williams ratchet from amazon but the pic shows the selector has a screw going thru it and the selector in the kit doesn't ????
Same pic and part # shows a screw in the selector on jh williams website. Says made in usa?
i still don't understand this tool. What are you guys putting on these that 1/4" drive sockets won't do?
i still don't understand this tool. What are you guys putting on these that 1/4" drive sockets won't do? Is this for bit sockets?
Snap On makes up to 15mm in 1/4" drive. For engine work on new US and Japanese cars, that means you can wrench an M10 with 1/4" drive. That covers quite a lot of engine components.
German cars will top out at M8 since DIN M8 is 17mm. So is that what you are doing? Putting 17mm sockets on a 1/4" ratchet? Anybody got any specific applications of why this is necessary? Or is the issue here bit sockets or etorx?
Its called limited access. with a 1/4 ratchet body on a 3/8 socket, you might get a 90 degree swing for running down a bolt or nut. Then you can switch to a std length for final torque, where you might only have one or two teeth of swing useable...
I just don't get why guys think this is a good idea or is a better solution.
Build one and find out. No stubby 3/8's can go where these 1/4 bodies go.
Sorry to be obtuse. A stubby 3/8 ratchet is often shorter than a small 1/4 ratchet. If it's the length of the ratchet...
I think some guys are looking for the thinnest head to help remove a long bolt from a tight space. A 1/4 ratchet is thinner than any 3/8. But there are new low profile ratchets out there.
If this is something you guys just think is cool, that's cool with me. You don't need a reason for everything. I just don't get why guys think this is a good idea or is a better solution.
Here is some data here.
Here's another contender from Carlyle via NAPA:
http://www.napaonline.com/Catalog/C...rdrop-Slim-Stubby-3-8-/_/R-CHQR38S_0151389659
Carlyle makes some Mac ratchets; I am guessing the above is similar to the Mac XR5MK except with a different handle. Although the two have different tooth counts, hmmmmmm…
That looks like a stubby, not a compact.![]()
First Guess: Carlyle doesn't MAKE anything. Carlyle (NAPA) buys from outside sources who make stuff to NAPA specs, stamp "Carlyle" on it, and wrap in in "Carlyle" packaging.Carlyle makes some Mac ratchets
Second Guess: The people who make Carlyle ratchets may also make Mac ratchets. Since Mac Tools is a division of Stanley Black and Decker which also includes Proto and multiple other brand names, I'd say that IF (big IF) the Carlyle and Mac ratchets are related, then NAPA has contracted with Stanley Black and Decker/Proto for some of their tools.
I think it's more likely that the Carlyle and Mac ratchets are unrelated.
