Whoo!WHOO!
I know some are still waiting... but its HERE!
After 4 months-sorta hard to believe. As I hadn't picked up plug yet I cant test. Sure hope it works as I also found some issues and felt compelled to address. Some mods and chages- probably add to the "now I've a cutter thread" but for those 'inspecting' Ill add what I found.
I'm pretty stoked- for $200 gladly play with it to get going and fix how I think it should be.
That said, Same as so far identified, main power cord nut loose, though I m replacing with longer cord. The torch connections, yup accident waiting to happen. As they're pretty long eventually get reworked- maybe some small tube or add shrink tube till the wires are restrained. But later.
What I did find was clearance issues. Middle board was tweaked pretty bad.
Like flexed downward almost 3/16".
I loosened the nut, top of copper L bar- you can see the board relaxed upward. Loosened the nut air/torch connection, nope wont go up any more.
Removed the L bracket and slotted. Checked the other side. ok
top right side by ground screw (removed as I'm rewiring) Noticed the small vertical board on top was under cross bar pushing it down good 1/8". I removed the side cross angle and notched. Board now setting at angle?
Checked other side cross bar angle and red/back wires from forward most plug were tight against it-pushing down board.
Removed cross bar and notched.
Lastly forward part of top main board hangs out unsupported 3", so I need to make some sort of stand off to immobilize. A good jar or vibration could easily cause board trace fail. Minor stuff really-IF this works-I should have tested 1st.
I did rework the line in the back. One was the orange gauge line. Pulled out and enlarged hole for grommet-didn't like direct metal on tube.
I'm going to get an air drier eventually, if this works-got short air line to run between cutter and drier but as I haven't picked drier up yet so plumbed small inline.
I thought Aquamooses idea for tidying up was a good idea. Unless it really bugs you I wouldn't recommend. Bit of work. However
Inlet is directly connected to small valve inside you need to access, removal requires a bit of effort.
Finally got it but painful, though mostly because I wanted valve and fitting to sandwich case. Easier if valve otherwise secured, open up thru hole case and just poke fitting thru-one of those commitment thing once started but I was regretting it. Took way too much effort but turned out nice though wouldnt do again...
