Need a Reliable Stud Finder
jimgood
Marshall, VA
WALL STUDS, IDIOT!!! :lol_hitti
I've had a Zircon stud finder for many years and it's been pretty good. But, today, it was absolutely miserable. I was trying to locate studs to mount a hanger for my QuickJacks. Every time it lit up to indicate a stud location, I would drill through the drywall into thin air!
I tried knock testing but I wasn't 100% sure. I ended up drilling small holes 1/2" apart horizontally until I hit wood. It was maddening! I ran the stud finder over those areas again and it still did not indicate over those spots. WTF!?!
And, yes, I know how to use the thing. You hold it over a spot where you're sure there is no stud, hold the button, wait for the light to go out, then slide horizontally until it lights up again. Pretty simple.
So, maybe it's just old. I put a fresh battery in it so I know that's not the issue.
So, besides the knock test, what do you guys use?
In case you're wondering, this is what I was mounting: http://www.garagejournal.com/forum/showpost.php?p=4961160&postcount=24
J
jimgood
Marshall, VA
Look no further... I thought EVERY wall stud finder was worthless until I tried this.
http://www.amazon.com/gp/product/B0064EICKG?psc=1&redirect=true&ref_=ox_sc_sfl_title_9&smid=ATVPDKIKX0DER
Right after I posted this thread I did a search on stud finders and that one comes up as being highly rated. I like the way it's designed. Pricey though.
The pro sensor works well, but a simple magnet is hard to beat
http://www.amazon.com/dp/B000IKK0OI/?tag=atomicindus08-20
****. If I had used my noggen! I have some rare earth magnets on my work bench.
dngrmse
Northern NJ
I tried a few different zircon ones, false readings on just about everyone I ever owned. I bought a magnet at Home Depot, and haven't looked back since.
Gotcha640
Houston TX
If I have something that needs to mount directly to the stud, I'll cut the drywall and make proper mounts.
I also use a bent wire, drill about 1/4" hole, put about 6 inches of coat hanger in the wall, bend it around, and rotate it until you hit the stud. You know the angle and the distance, so you know where the stud is. I'm about to do that all over a finished garage for French cleats, and I'll cover the holes with the cleats.
Zartan
Mountain House, CA
I have a collection of questionable ones, so I just bought a Milwaukee Sub-Scanner
orca8589
Concord, CA
I have a Zircon, and for the last several years I've been using a little Stanley #47-400 magnetic stud finer. I kept having problems with "phantom" studs (and useless extra holes) from the Zircon.
The #47-400 is a little tedious at times, but once you're used to it, it works fine.
~Chris
bobcatdan
Kaukauna,WI
I have $40 zircon. It's hit and miss. I have found what works best for me is find one stud and use a tape measure from there.
ozyborn
My wife did a great job. She found me.
But to your question. I have used several different electronic ones in my job and the magnetic type. But the thermal scanner is the best by far. Bit on the $$ side. But I found one at an auction that I picked up for under $100.
kstools
http://www.amazon.com/dp/B00E01R4U4/?tag=atomicindus08-20
I have a couple of this style of shinwa stud finder. I use these when I absolutely need to know each edge of stud. The pin hole is almost invisible. This also shows wall thickness. A fancier option to the tack nail I guess.
I also use a shinwa 78674.
http://global.rakuten.com/en/store/maru9/item/shinwa_78674/?s-id=borderless_recommend_item_en
Works like other magnetic finders and has a pin that moves to show when centered over nail or stud. Quick and easy.
Both have certain limitations but I find these to be foolproof for the most part. Would be hard to go back to the electronic ones, short of a sub scanner.
Zrexxer
Pflugerville, TX
I use both the Franklin electronic one and the Hanson magnetic one in concert. Pretty happy with both of them, but they each have their strengths.
J
jimgood
Marshall, VA
With the magnet, it seems like you would have to hunt around more to find either drywall nails or nails where the studs meet the floor/top plate. Is that right?
bcradio
New Mexico
On wood studs yes. And then you have to hope that the nail/screw was put in correctly (on a stud and in the center of the stud) by the drywall installer.
There must be lots of people in here with metal studs.
mossyboy6
St. Pete, FL
I haven't even pulled out an electric stud finder since I got the little magnetic one. Love that little thing, use it almost every day at work.
I also use it all the time finding dropped screws, bits, etc...
NewShockerGuy
Northern Virginia / DC
Interested as why you do the drywall removal? I have just acquired two large wall cabinets that must weigh in at 80lbs-100lbs... 77" wide, 44" height, 12" depth. I have normally hung everything onto studs but never cut the dry wall underneath...
If I am hitting studs every 12" in the garage to support the 77" wide cabinet and anchoring it in say 3 screws per 12" would that be enough via the height of 44"? IE: 6 screws per row and 3 rows... So 18 deck screws that are going into the back of the solid plywood cabinet into 6 studs....
Row 1. * * * * * *
Row 2. * * * * * *
Row 3. * * * * * *
thanks,
-Nigel
Gotcha640
Houston TX
I cut in to the drywall when I want the stronger attachment. For example, I'm putting up a foldup table on the wall in my garage (hesitate to call it a work bench, more of an assembly table, but I'll do things like soldering and drilling, no hammering).
The wall side will attach to a 2x4 that I cut the drywall to attach directly to the studs, and I also cut in at the footer to attach some angle braces.
The way I look at it is, if this table is unfolded, and my neighbor walks in with a lawnmower engine, or my wife comes in with three gallons of paint, or my brother comes over with a whole pig over his shoulder (happened before...) and dumps it on the first flat surface they see, I don't want it collapsing/tearing off the wall.
If you put your cabinet up and you keep shop towels or small hand tools, or otherwise keep it for light use, and then someone decides it looks like a great place to keep their anvil collection, will it hold?
I'm probably overthinking it, but that's what work is for, right? Planning for the weekend in the garage.
rharman
SoCal
I have the blue one just like this that came from Costco. it works great and the price at Costco was $39.99
bob
I've had one for a few years. Works great except over stucco (in my case). Otherwise it is awesome.
Pricey, yes. Seen them at Costco and wondered if it is exactly the same or a cheapened version for Costco.
When I bought mine, it was on Small Business Saturday and I got $25 back from Amex. Great deal.
cbracer
Costa Mesa, CA
I got mine at Costco, it's blue instead of yellow. Absolutely better than Zircon, which is a joke. Had two of them and they hardly worked.
