Anyone here have a HF socket or wrench failure?
MrGiggles
I've had
A 1/2" impact extension explode on me.
A pair of slip joints jump and smash my finger good.
A flip socket crack.
Don't think I have ever used their wrenches.
I despise cheap slip joint pliers for that reason.. It only takes one smashed appendage to ruin them for me.
I'm the new guy here, so I'm not sure if this is a serious post. FWIW, I'm not the kind of person who cares what other people think, so I'm ok having non-premium tools for what I do.
Will do, thanks.
I am more concerned with the changes in temperature forming condensation, especially in a damp garage.
My garage isn't heated either, and even the cheap tools in my box haven't rusted or otherwise been affected by the temperature swings. I even have a "custom" thin wall 18mm deep that I ground all the chrome off of, and it has barely rusted.
T
thool
Rochester, NY
http://www.garagejournal.com/forum/showthread.php?t=295926
Read this.
Decide if want to work with the sixty percent or so people who are like this.
You're on the right path tool wise... Right now....
It was never my intent to turn this into a battle between tool brands. There are plenty of such threads already.
I was just looking to see if HF sockets and combo wrenches would be a good fit for me based upon my current usage. For other tools like screwdrivers and adjustable wrenches, it may be other brands (I have a nice Stanley set of screwdrivers and Channel Lock adjustable with the lt blue handles).
Thanks.
mfewtrail
The only HF sockets I have are the pro version of the impact sockets. They've held up well with frequent use in the little over a year that I've had them. I used them daily for several months last year with no breakages.
KEH
What fliver250 said.
IMO import impact sockets in general seem to hold up pretty well. HF ones seem to be as good as any, not including Sunnex, which is very good.
Where it pays to spend the big bucks for tool, IMO, is screwdrivers, especially Phillips type. I have bent too many cheaper brands even not being a professional mechanic. Cheaper Phillips types don't always fit the fastner well, but then I'm not a fan of Chinese fastners either.
Ratchets are another area where quality pays. The tool truck ratchets are all nice and rugged, but costly. Less expensive but good alternatives are SK, Wright, and Proto. I guess Proto is less expensive, but not by much. The old Proto pear head has been around since the 1930s and has stoo the test of time. Other good alternatives are availiable.
A good breaker bar is valuable. An alternative to quality ones is to get an HF 3/4 one, use adapters for smaller sockets, and have a length of pipe to use as acheater bar.
KEH
hangfirew8
Central Maryland
So will HF sockets and wrenches hold up as well or better? I like the polished ones.
Avoid the $5 "40 Pc 3/8 in., 1/4 in. Drive SAE & Metric Socket Set". I had this set. I stripped every socket on first use, and finally bent the round head of the ratchet with a different brand socket. With all the most-used sockets and the ratchet gone, I threw away the rest.
I understand some of the more expensive chrome sockets are better. I wouldn't know because I don't buy them. Well I have a set of Splines but I plan to use these as disposable nut busters.
The only other HF sockets I own now are a few of the 1/2" impacts I bought as gap fillers. Most are rarely used sizes so they'll probably last forever.
HanShotFirst
NW Nevada
I recently picked up a HF synthetic 3/8" fine tooth ratchet; all my ratchets are coarse, old school. I decided to give it a try after watching a Youtube video where it went over 300ft-lbs before it broke. I like that it's very light weight and has a longer handle than my Craftsman, Husky, Kobalt, or SK. After working with it, I generally like it, but have one minor complaint. the handle has a "non slip" rubber section and that gets greased up and doesn't clean up nearly as easy as high polished chrome. Honestly that's my only criticism, other than that, it's a damn good ratchet.
I'm not a pro wrencher. I probably do in a lifetime what a pro does in a year or two, so I'm betting this ratchet lasts a lifetime.
I have a full set of Pittsburg sockets in all sizes both English and metric. The sockets have been flawless performers. The ratchets are the much older style and I don't like them, but they have NEVER failed me. I very much like the newer HF ratchets.
Parrothead
Earth
Here's my take on the HF sockets and wrenches (I've owned/own both).
Combo Wrenches - The wrenches are the low end of the spectrum as far as usable wrenches go. I've used them in the junk yard and they've been fine so far, but they are short. something to keep in mind. I probably wouldn't purchase them again. They've been relegated to the box of tools I likely won't use again. If I were in your spot, I'd purchase the Tekton combination wrench set for $59.
http://www.amazon.com/dp/B00OXUPMGK/?tag=atomicindus08-20
It's a little more expensive, but MUCH better quality and no skips. I really hate missing sizes, so that's does it for me. There are skips in the HF set
Sockets - Pittsburgh Pro are very good, and if you buy the set, you get the 72t ratchet with them. I've been impressed with them, and those I would buy again. However, they do have skips, so something to keep in mind.
I'd probably go with the Husky sockets and ratchet from Home Depot. There's a thread here of a dual stamped Matco Silver Eagle/Husky socket. I guess if they're good enough for Matco, I can certainly use them for my road box. The other thing is you can complete sets and get quick replacements off the shelf. They're made by APEX (aka the Gearwrench company) Again HF skips sizes.
I'd look into Tekton for pliers as well. Made by Wilde USA. You'll know which ones as they'll say Made in USA right on them. Not a fan of the Chinese versions though. I like them better than Channellock, even for their grove joint pliers. The Tekton's have an adjustable nut vs. the permalock thing on the Channellocks.
MikeF2316
Thornhill, ON
If you can't do the job with those tools, there is a weakness that is not related to those tools.
Someone here should do a swap meet find wrench comparison.
A fifty ton press and a grade eight bolt.
Open end
Closed end
Sockets.
Hf Vs any truck brand.
Then see which gets warranted faster including shipping.
Then we can ALL shut up.
Your last sentence is the only thing that will never happen. :lol_hitti
AmishFury
there are some skips in that set... the 30pc set has no skips though it's a better deal buying the separate 15pc sets ($100 for the 30pc $83 for the two 15 pc sets that make up the 30pc)
maxpower_hd
Massachusetts
I have had plenty of HF fails to the point I won't buy their stuff any more. And as far as comparing them to the newer Crapsman brand? I don't buy those either.
Brownsfan
Cleveland Ohio
From normal use? Like no cheater bar, no beating it with a sledge, etc?
I'm asking because I'm looking to build up a wrench and socket supply in their 44" base cabinet, and have heard their tools have come a long way. Over the span of 30+ years I've had a few of: craftsman, husky, kmart, ace, fuller. The only ones that have failed were the Husky ratchets, from Home Depot and they were made in USA. The replacements from China are still rocking.
So will HF sockets and wrenches hold up as well or better? I like the polished ones.[/QUOT
The Pro series sockets will work fine. Not sure about the wrenches. I looked at them for my mobile service kit and they just looked bad. I bought some Husky instead. The new Husky stuff is pretty much identical to Gearwrench. I replaced a missing gearwrench socket with a Husky and the only difference is the Husky stamp. Everything else is IDENTICAL. The new Husky stuff is actually pretty damn good for the money. That's where I would be looking for cheap serviceable tools.
Parrothead
Earth
I stand corrected. I have the bigger sets. My mistake to the OP too.
Parrothead
Earth
I pretty much agree with that statement, but I didn't really like the lobsterish claw on the Husky wrenches, the Tekton's are much better and made in Taiwan vs. the Chinese Huskys. I really like the 72t Husky ratchets though. Thin head, quick release and 72t. One of the best values out there.
HanShotFirst
NW Nevada
Depending on what you're buying from Tekton...
Their ratchets & sockets look exactly like the Harbor Freight stuff to me; probably made in the same factory. Nothing wrong with that, I think HF's sockets and ratchets are downright good these days.
Their screwdrivers are exactly like the HF ones, just a different color handle. Again, nothing wrong with that, the HF screwdrivers are damn decent for the price.
As for pliers, I've seen some that looked like they were made in the US, and I've seen a set that was almost indistinguishable from Harbor Freight. For standard pliers, I find the Harbor Freight ones to be great. For Channelock type, I'd rather just buy the name brand.
My point is, if it's the same tool, you don't have to pay more unless you just want to pay for a different name on the tool.
Now their combination wrenches are a different story, they look much more like my set of Cobalt wrenches; which is to say, they're downright decent wrenches. I'd recommend the Tekton high polish combination wrenches in a New York Minute!!! That set you linked to just may get purchased by me too; I'm getting tools together for my son's tool box.
All in all I'm liking Tekton as a brand. The stuff they have that is a duplicate of HF seems to pull from HF's best lines, and where the HF stuff is weak, they obviously go elsewhere.
Adam.C
I'd be more concerned with what low quality tools can do to automotive fasteners. For stuff around the house, I'm sure these tools, any tools, will be fine. But I'd be careful using a cheap open end wrench on a small, highly torqued, fastener. Ditto sometimes the smaller sockets fit looser than larger sizes.
Some mechanics are particularly sympathetic to their tools and hardware. These guys can use any tools. So getting recommendations from them may not help you. The key is to know your tools' limits. I wouldn't trust HF on a difficult automotive task. But you could be okay if you are careful.
defektes
Arizona
As far as condensation your best bet is to spray the tools every so often with silicone spray and wipe clean. The silicone will leave a layer of coating to protect the tool. It wont prevent all rust, but it will mitigate it. I work in a very wet environment I do the above and the occasional drop the tool in a bucket of oil works too. This goes for any brand tool.
HanShotFirst
NW Nevada
Yeah, my biggest concern with the Chinese stuff is fit, and with open end wrenches, expansion. My HF sockets have yet to trash a fastner that wasn't already trashed; ones that any socket would trash. I don't have any HF wrenches, I can't bring myself to buying any. But I may pick some up for spares just to have around.
01f1502wd
So far, the only socket I have broken was on a lawn mower, old craftsman regular socket, before I had impact sockets.
Other than that after working on several jeeps, trucks and jacked up SUVs (engine and suspension) I have yet to break any other sockets, I have a set of Ingresol Rand, Craftsman, Kobalt and HF sockets. wrenches I broke a Husky 3/4 ratcheting wrench, but out of my craftsman, kobalt and Husky none others....
I have a bad habit of leaving the hammer across the garage..usually a cresent/wrench or socket wrench will work hahaha all still work just fine!
404
Mass
Have the 1/2 drive deep impact HF in metric and imperial, no problems with either.
BDT/NWMN
Erskine, Mn
IMO HF is low class junk I would not own. You can find Craigslist and garage sale tools made in America for pennies on the dollar and have something that lasts forever. Maybe I am a snob, but there is something that is just downright embarrassing about them. You certainly couldn't show them to friends and family without them speaking in hushed tones behind your back.
I could preach a sermon; but I will just quote you: lol::lol::lol::lol::lol:
I split a 3/4 long length combination wrench down the center of the handle with a mild pull.. My 3/4 ratchet didn't work when new.. There were razor sharp teeth in one side of the housing, and mere bumps on the other.
The famous 1/2" drive 24" breaker bar snapped with a one hand pull.
Water pump pliers jump settings
OK the famous HF warranty will come to the rescue.
Some of the HF stuff I actually like... I will not call it 100% useless junk
But there is a bunch of it that I have no use for... It pisses me off when I put one of those cheapo wrenches on a bolt and feel it give when I start to pull.
I have about 7 sets tied together in my junk tool box.. Thinking about cutting them down to stubbies.. might be strong enough for that purpose... :p
valentine
I'd say that Harbor Freight tools have improved to about the same degree that Craftsman tools have gotten worse. What that means to me is that I'm less likely to buy Craftsman and more likely to buy HF. Recent HF purchases include their composite ratchets, breaker bar, and locking oil filter wrench. So far I've been very happy with those tools and have had no problems whatsoever. I will point out that the ratchet internals were bone dry so I opened them up and lubed them. Would not own HF wrenches; they look and feel like the crappy free tools you get when you buy some Japanese manufactured power equipment; really cheap. Their sockets don't make me feel any better. I know their impact sockets get good reviews. I'd give them a try. For good, inexpensive tools from a brick and mortar retailer I like Kobalt and Husky. If you are willing to wait for a mail order delivery, give Toptul a try. I've been getting more and more of their stuff amd have to say how impressed I am with it. Haven't seen a bad Toptul tool yet.
-Valentine
619DioFan
San Diego , Ca.
I have broken / cracked several of the older version impact sockets. since the set was so cheap I didn't bother to replace them. I will say that I have several sets of the pro series impact sockets and have wailed on them with zero problems. I have also never had a problem with their impact extensions. I have several sets of the pro series chrome sockets and they have been great also ( never use them on an impact ) I don't own any wrenches from HF so can't comment there.
Adam.C
Does 14mm count as a smaller socket? Even the good old USA-made chrome 3/8" sockets can cause problems on small, highly torqued fasteners. As an example, I recently had a 30-year old Cman-USA 3/8" drive 14mm socket fit kind of loose on an automotive fastener. It kept slipping off when using a ratcheting handle. A brand new Cman-China 1/2" drive 14mm impact socket on a ratcheting handle fit nice and tight and took the bolt out with no problems. Not sure if it was a size differential or the impact socket just had a better grip than the chromed socket.
Breaking tools is the wrong measure of the suitability of tools. The devil is in the details.
14mm is the JIS size for an M10. It can be torqued at the factory at 55ftlbs. Generally, I think any bolt can easily get stuck requiring double its std torque (due to high static friction caused by corrosion etc). So you could be putting 100ftlbs thru that 14mm socket. Japanese car makers use bolts with smaller heads than everyone else. That makes them generally harder to remove.
The inside profile of a wrench or socket is a complicated shape. You can't simply make a hex slightly larger than the greatest size bolt head. In use, the socket will bear against the fastener's corners and round them over. If you simply relieve the corner (like an impact socket for example), you will contact the bolt head at an infintessimal line until either to the socket or the bolt yields. So manufacturers have all developed special curved shapes inside their sockets to allow a range of fastsner head sizes to contact the socket in the right place with area contact.
If you don't have a very well formed profile inside the socket, the contact patches between the socket and the bolt head could be tiny (line contact). Since stress = load/area, you don't need tons of load to yield (round) a screw head when the area is small (loose fitting socket). That, in a nut shell, is how stuff gets rounded.
The problem with cheap tools is twofold:
1) The shapes of them may not be ideal. Sockets are made by a cold forging/broaching proccess. In use, the broaching tool (forging die) wears. It has to be inspected regularly and replaced. My guess is, Chinese companies don't/can't do this. They are more likely check the sockets, replacing the expensive die only when the sockets get really bad. So you will likely see fairly significant dimensional changes in the inner profiles of cheap sockets. Some people here will have good experiences, especially those who were the early adopters who got the new model of sockets when the dies were fresh. Same is true of wrenches, etc.
2) Good materials are NOT easily had outside first world nations. You guys who haven't lived there or worked with foreign suppliers just don't understand. These are countries that don't have clean water. Clean steel is literally too much to ask. The Chinese build apartmemnt buildings that collapse due to poor quality steel. So despite the manufacturers' best efforts, they never realy know what steel is coming in the door. (to heat treat steel effectively, you must know it's exact make up).
America is not a perfect society. We hold people legally responsible for stuff, which many of us complain about. The threat of lawsuits is a constant concern for business owners. Consequently, we are pretty sure about what we make, even our trash has to consist of what we say it consists of. We also take great pride in our work, which honestly isn't true everywhere. Many people making our clothes, shoes and maybe even tools in the third world are in survival conditions, doing what they must to survive and feed their children. Consequently, **** happens and bad products get shipped. That's just the way our world is at present.
When the product is a hammer, none of this matters. And steel is pretty dog-gone strong, even if it is dirty or mishandled in heat treat. You just have to look out for items where a tiny bit of tool wear (forging dies) will make a significant percent difference in the finished product. And then it is only an issue when you are trying to remove something stuck.
Unfortunatley for me, nearly every automotive job I do includes something stuck. I typically don't work on cars that are covered by factory warranties (like many dealer mechanics do). I work on cars when they are older and out of warranty when stuff is good and corroded. And since my time is precious to me, I am happy to spend an extra $100 on a set of tools that wont let me down. So that's why I make the recommendations I do. But if you are in plant maintenance or are fixing lawn mowers maybe none of this matters.
Hopefully, this explains why some guys prefer certain tools, regardless of whether it breaks less than another brand. More to tools than how often they break.
1950mercury
metro detroit
I just bought some 1/4 drive sae chrome sockets and I can't complain for the price.
I also bought a 1/4 drive sae chrome sk set and one is effective, I have to call hje in the morning
MattVette89
SW Chicago
Since this thread was brought up again...
I broke a few of the older Pittsburgh impacts on a regular gun (they were probably from 2005 era) but the newer style single one I use for lugnuts seems to hold up well. I used the long hex extension the other day with a manual impact driver (not it's intended use) and it held up fine. I have other various HF tools. I would avoid the really cheap socket sets as advised above. I bought the Pittsburgh Pro chrome set for my brother for a garage set and I have been impressed with the quality so far.
ssdave
Eastern Oregon
Responding to the original post, I have to comment.
If you've been happy with Kmart and Fuller and Husky Chinese tools you've been using, you'll be pleased with the HF ones. Some guys use their tools very sparingly, and don't have the situation to need great tools. In those cases, you're just as well off saving the money and buying those minimal quality tools that will suit your needs.
If you have fasteners that are rounding off due to poor fit, if you have some tools failing, if your tools are wearing out, then you need to have better quality. If those things aren't happening with the poor quality Kmart and Fuller you have now, it won't happen to the HF ones either.
You specifically say you don't care for the visual & prestige aspects of the tools, so you can get by for pretty cheap by not paying for non-performance features like style and full polish.
From a cost standpoint, you're in a near perfect situation. You don't need quality for your work, and you don't care what they look like. You're the market poster boy for Chinese and Indian tools, and can reap the economic benefits of your preference, while still meeting your needs.
volaredon
IL
nope not me. but then again I have never bought any sockets/wrenches from there either.
winlinmac
USA
Their CR-MO Impact Sockets are the best bang for the buck. The Chrome Molybdenum is key to quality. Tekton's impact sockets are only rated Chrome Vanadium. With similar pricing, Harbor Freight wins in this category. Also, note, "ALL" Pittsburgh Pro Sockets and Pittsburgh Impact Sockets as well as Ratcheting Wrenches are Made in Taiwan. If you haven't been to Harbor Freight in years, I'd suggest to check out their new sockets. Their sockets are perfect for the weekend warrior, DIY, and homeowner. You're not settling for less here Ladies and Gentlemen. RIP Craftsman ;)
Jsf721
LI, NY
I own a full set of metric and sae 1/4,3/8 a day 1/2 sockets. I use the hard but properly. Never had an issue. I purchased the entire set after hurrican sandy whiped out my entire tool box. I went to get replacement craftsmen but they tools were not as nice as they once were and much more expensive than HF. I am a fan of some of their tools. Mine are not the pro version. They are 2-3 years old.
Also avoid screwdrivers my experience is poor with those. I purchased a snap on ratcheting set and it's great. I have a full fellows set and it's great.
SantaAna12
Well said.
Al Borland
Work used to buy a lot of stuff at HF.
Some good, some not-so-much. Thinking was: If the employees are going to lose or abuse the tools, why pay more.
Impacts haven't failed (on a breaker with 3' of pipe)
Chrome sockets were ill-fitting and cracked with moderate use and a little abuse.
Roundhead ratchets fail (pawl/teeth) no pipe involved, breaker bars fail at pivot (3' pipe again)
Open end wrenches got to be REALLY open ended (no cheater pipe)
Screwdrivers are mostly decorative (and that is being charitable)
Crowbars bend fairly easily, even the big ones.
Hammers had heads out of square with the handles, so they were a P.I.T.A. to drive a nail with. Broke handles pulling nails. (Handles might have been bamboo or some kind of shrubbery/weedy underbrush)
I have yet to see the power tool that was worth having.
I DID have an old orange 18v cordless drill that worked great, but after about 8 years, the plastic body got brittle and it exploded driving drywall screws. Got my money out of it though. 8 years for 29 bucks.
Currently, management gets semi-middle-of-the-road tools instead. (Husky/Kobalt)
They withstand more abuse, but tend to disappear at the end of projects. HF stuff was more likely to make it back to the shop.
bcradio
New Mexico
Some serious tool abuse here... that'll definitely test the limits of the tools.
:lol_hitti
Al Borland
Absolutely some real-world use (abuse). Some things held up better than others.
However, the newer (HD/Lowes) stuff seems to hold up under the same conditions.
PJNJ
Iowa
Their CR-MO Impact Sockets are the best bang for the buck. The Chrome Molybdenum is key to quality. Tekton's impact sockets are only rated Chrome Vanadium. With similar pricing, Harbor Freight wins in this category. ....
HF Pittsburgh Pro Impact sockets are good. But not necessarily better than Tekton. There's a little more to it than Chrome Moly wins every time over Chrome Van.
Suggest you do a little research before making blanket statements like that.
:beer:
Forever Fixin
MN
Out of my HF collection I've had mostly their extensions fail. The 1/2" impact locking extension sheared off the locking collar. And I twisted off the end of a 3/8" 6" chrome locking extension with a crows foot on one end and a 3/8" breaker bar on the other, that was spectacular. Also had an 8mm ratcheting wrench fail. All have been covered under warranty, no questions asked.
