The repurposing thread
Fyrme
Green country, Oklahoma
Nice. So what are your plans for weather proofing it? Some kind of dog house? Or a quick release set up where you can take it inside?
You could find you a double sprocket and rig it at the bottom of the track. Then relocate the motor under the stairs, out of the way and run the primary chain from the motor over to the sprocket.
valentine
Lots of good stuff here Fellas. Keep those ideas coming. I'm inspired.
-Valentine
kbs2244
If your treadmill cover will not fit, try a plastic 55 gal drum custom cut.
I had a 5 gal pail, with part of the side cut out, over my swimming pool motor for 6 years.
little d
NW Oklahoma
Bub,
before you relocate the lift, ya might try a arm that pivots, you could load it swung out and then swing it over the landing once it gets to the top.
Beaumont67
St. Thomas, Ontario
Homemade Ultra-Light FLIRT POLE, material list:
a) new graphite golf shaft, from a $400 Big Bertha driver tear down...helps my twin bro is a custom club maker, got it free
b) nylon twine........had some
c) used nut on grip end to tie & secure braided line inside shaft, without pulling through
Total cost = 5 bucks
- repurposed shaft is very strong, incredibly light and most comfortable hand grip
Dad, lets go play FLIRT with me, in the snow....daaaad, girly waiting...get them boots on !!
Beaumont67
St. Thomas, Ontario
Kelly's family has a newer SUV (2008 Toyota RAV4) and Dad doesn't want to clean nose prints of front windows, on a daily basis:
So I cut the padded shoulder strap off an old & damaged golf bag.
- used the re-purposed harness to restrict girl from jumping into leather bucket seats, at will
- the shoulder harness on junked golf bag, had 4 nylon anchor straps
- 2 straps were threaded around the top head rest posts / other 2 straps (longer) were threaded on the back seat frame brackets, on the floor
Beaumont67
St. Thomas, Ontario
A few months ago, I was cleaning out a storage barn & someone left behind an old grocery bag cart, so I took it home.
And recently, we had major wind & both my recycle blue boxes were across the road, and recycle contents all over the neighbor's yard.
(which I picked up)
So I re-purposed the free grocery cart into a blue box cart.
- top blue box for cans & glass
- smaller blue box on bottom, for broken down cardboard boxes
Old cart, worked out perfect.
bubinga
Bub,
good Idea too, actually I was just planing on extending from the hole, a I bolt, and my hook off of that.
But the pivoting arm is a good option if the eye bolt only does not work out.
MarkG
Elgin, IL
Re: Vice re-purposed to mini workbench
Casters on a workbench will drive you nuts if you ever do any serious work on it! Whether they 'lock' or not, they will roll/spin. Bench construction itself looks great, but in my experience, it's impossible to have a bench that's 'too solid' or 'too heavy' and the combination of small size and the castors would cause me problems with that design. Anchoring my bench to the concrete floor with screws was the best thing I did to my bench!
Nice workmanship, nevertheless.
BajaScout
San Diego, CA
John Deere 265 Lawn Mower Throttle Lever... now the cowl vent lever on my '27 Ford RPU:
I saw the picture with the mountains in the background and immediately thought Colorado. I grew up in Berthoud and haven't been back in a long time. Looks like Longs Peak in the background. Nice shot. Brings back memories.
RC000E
I just picked up 22 road signs from a government auction I am about to jump into. This has been a great thread to browse through.
BD1
north side
The piece of wood is from when my son had snakes and lizards 20 years ago. The silverware is from Goodwill.
Made this for my son and his girlfriend, they fish a lot.
ADSR
very cool!
Grimly
Ireland
Struck by a need for a welding cart, and realising I had one under my nose...
Take a KitKat display trolley - which had been doing sterling service as a holder of soap powder and other **** by the washer/ drier for a decade
It had been so long since it was put there, I'd forgotten it had castors.
Add some green wire shelving which was kicking around, but turned upside down so they have a lip all around...
The shelves were almost a perfect fit for it - just supported by some 1" copper pipe at front (with Jub clips) and resting on wire stays on the rear. The whole thing tightened up with plenty of tie-wraps, the bodger's friend.
And, here we go...
It will do for now, simply as proof of concept, or something like that. I might improve it, if I cba.
Grimly
Ireland
I was casting around, looking for material to press into service as cheap welding curtains, when inspiration struck.
I noticed some of the commercial welding screens were fibreglass curtains, but the penny didn't drop quite then, but it did later - FIBREGLASS CURTAINS! (or drapes, for you lot)
Items that were hated by a generation of small boys when they rubbed against them, or their Ma washed them in the machine, followed by the family's underwear.
Anyway, they totally fell out of use and fashion, and can now be picked up dirt cheap. Fireproof, rot-proof, taste-proof, and easily hung for my purposes.
15metres of 48" fibreglass fabric in a not-so-tasteful Autumn brown leafy pattern for £15 - can't beat that.
Plus, it will cheer up the workshop no end :)
bubinga
And, here we go...
Nice, does it roll around nice?
Good idea,
Thumper68
Duluth MN
Do you have a link? or a brand?
rmalkow2
Brighton, MI
Now that improvement needs a picture or two. I'm trying to picture that leafy pattern look.:D
great white tj
Ocala Fl.
I found this rusted out water hose reel, removed the reel... added two pc. of bed frame angle. Now all I have to do now is get the stick Gods to work with me a little..
Grimly
Ireland
Good idea,
It rolls ok but I have some larger hospital castors I can put on it. For now though; it works well enough, and the handiest thing about it is simply having the welder in a more convenient position and higher up off the floor, as the captive lead is a bit on the short side.
Feast your eyes...
http://www.ebay.co.uk/itm/171858429224
hewey
Blue Mountains, Australia
Pallets into christmas decorations, with a little vintage sign inspiration. Made it in two halves so it could be stored easily.
And for something different, timber saw horse turned in to a lasso game for our wedding. Made for fun pics.
hewey
Thanks mate. I did the painting, design was one I found online, had it copied onto a transparency (acetate), traced the design, and then hand painted it.
