The repurposing thread
OccupantRJ
Eastern North Carolina
ICE PICK
I have been working on resealing driveway cracks. Found that using an ice pick with the tip bent at 90 degrees helps get the **** out of the crevices. the only problem was i hit a snag a couple of times and the pick came out of the handle. I tried several times making a new handle but nothing retained the pick part well. Desperate, I got out an old pair of regular pliers and the welder. after 5 minutes, the pliers became the new ice pick handle. pretty? NO , but functional.
Calling @BlakeTheCarGuy ! cpttuna modified a tool! On top of that he WELDED it! Oh, the humanity!🤭
OccupantRJ
More of a recycling than a repurposing, but there is a wellhead in our back yard so I built a low brick wall around it with bricks and leftover mortar a friend gave me and topped it with a free granite piece that I got from another friend who runs a countertop business. I used a flap wheel on an angle grinder to dress the granite edges. It made a great sitting bench on a nice day with the grandkid or dogs playing in the yard.IMG_1785.jpeg
mikeinri
Had 10 minutes of training 50 years ago. Also have nerve damage in both hands from my open heart surgery- otherwise steady as a rock.
You’re hired
Absolutely, has to be better than my welding "abilities." To be fair, when I was "trained" the guy training me would always reach down and adjust the welder before giving me the stick. Then, he'd adjust it again after I butchered the job and he went back to welding.
I didn't realize it at the time, but I'm figuring he cranked the heat (or whatever it's called) up or down so I'd fail, and he'd get to be the only welder.
Was a high school / college (summer and winter break) job, so I didn't really care. But, I do wish I could weld so I can build / fix stuff.
Mike
mikeinri
NICE!
Mike
cpttuna
napoleon ohio
Mike
I weld for myself. Only got into welding because I obtained the metal to build some firewood racks. I got a guy in town to weld them for $10 each. after spending $40 , I decided I could do this on my own if I had a welder. I maybe have welded something for another person twice in 50+ years.
rharman
SoCal
ICE PICK
txvwnut
Bedford, Texas
If you ever move get a tombstone made and put it there when you leave. Give the new owners something to think about.
fishwatcher
“Well.. I’ve retired two kitchen “tools and now might use them in the garage. As what? Cleaning vessels maybe?
One is a stoneware cassserole dish. The handles broke off. I have sanded them down. They could still be used in the kitchen, but it’s ugly and I have other casserole dishes without broken handles.
The other is a 4 quart Dutch oven. A quarter size chip of the enamel means the cast iron bottom and edge of the enamel is exposed. I sanded it smooth and am applying tub and tile touch up paint. That’ll seal up the hole, but it won’t be good to cook with. This can be a wash bin for parts cleaning.
Any other suggestions for how I could use these in my garage?
mikeinri
Any other suggestions for how I could use these in my garage? IMG_7505.jpegIMG_7507.jpeg
Cleaning vessels, or containers to put under oil bottles if refilling with used oil for recycling?
Mike
Miss the Pontiacs
Saskatchewan Canada
Needed a wheel assembly to assist in pulling Jetski lifts out of the water this fall.
I had the metal & PVC/ABS pipe, bolts, cable reels, pretty well everything except the wheels. Initally I used the cable reel ends for inner and outer wheel washers to keep wheels riding down the pipe or against the bolt. Then I remembered the wheels I was going to purchase were not as wide. Since I was at home and not at the lake I had to check lift width and sure as hell I was a little short.
Malfunction at the junction but we worked around the problem and came up with the difference.
I even had a little ABS to spare. 😂
