airrj
I have a new project for a friend that I am starting to design.
He has a 60 hp Kubota tractor with a Cat. II 3-point hitch that is rated for 3000#. He also has a 200 gallon skid mount sprayer that he has used for several years. The skid has been mounted on an old re-welded time and time again 3-point Carry-All.
Two things recently happened. First, the Carry-All snapped in half again at the point of one of the old welded on patches. Second, he was given a pair of 3500# forklift forks. A major score.
So, my task is to build a lifting 3-point attachment to carry the sprayer with the forks.
This is a similar style of sprayer:
This is the style of forks that he has:
Here are my first thoughts on a design for the frame.
The plan is a 2" solid bar across the top for the forks to hang from. The bar will go through each of the four vertical plates rather than just a **** weld. The verticals are 1/2" x 6" HRS. The two horizontal members will be 8" x 13.75# C-Channel. This C-Channel is 2-3/8" deep and the web is .3" thick.
The 3 - point hitch is 32" wide and 24" tall. The mounting points are shown by the little orange marks on the drawings.
Any thoughts? Too overbuilt for the application? Too light weight? All of the sizing has been by seat of the pants engineering. But if you saw the piece that was carrying this sprayer before, you would be amazed that it worked for 2 years. I have a large steel order going in this month, so I have to order steel soon, however the project won't likely be built until fall.
Thanks for your help.
