Bench Grinder hunt
How many folks has a bench grinder in their _______building at home for mower blades
  • Pay a outside source to do you mower blades
    Votes: 0 0.0%
  • Total voters
    33
Spookrider
Eaton, Indiana
I'm looking for decent bench grinder. For home use of mower blades and other little task.
I find a C-Man 6" for $60. and TSC same type a little less a Clark I believe.
What other decent maker for the home owner task is out there.
I like to stay in the $75. or less ballpark.
Also I throw this to justfy the need of getting one.
"how many folks has a bench grinder in their _______building at home for mower blades and other little tasks"
old salvage
Rhode Island
I had one up until recently. It was a vintage Black & Decker, probably from the 40's. About twice per lawn season I would use it to sharpen my mower blades. It was the 'Junior' model bench grinder but with a nice coarse wheel was plenty for everything I did. Took only a few passes to get the edges sharp.
Unfortunately the brushes wore down and new ones were no longer available. I looked into getting brushes for another motor and modifying them but the only ones that would have worked out were around 40 bucks each so its time for a new grinder.
Elroy
kentucky
Once you have a bench grinder, you'll wonder how you got along with out one
or two
or four
We like a Baldor.
Good hunting to you. Hope you find a grinder you're happy with. Buy a good one and they'll last a life time.
tatra
pirate contest city
i have access to all kinds of grinders at work and haven't had one in years...........i hate the dust and debris associated with them and am planning to build a water filter, much like a genie vacuum, as i find it a bit of a pain hauling things back and forth.........any suggestions welcome..........
fordracing200
I have one..its an old black and decker I got when I worked from Caldor free from the jewlery department back in the early 80s, Its junk...you put a 1x1 board on it and it'll stall, hahaha...forget grinding metal. I'm also on the prowl for a new one. Probably going to buy the HF pedestal to match it though.
Uncle Buck
Kansas
You cannot have a shop without a bench grinder and a decent vise. I just cannot imagine. Doing much work without both of those to use would be like going into a fight with one hand tied behind your back!
krooser
Waupaca, Wisconsin
I have three... my main one is a 6' 70's vintage MIJ that works fine and I paid $15.00 for it...IIRC.
I also have a Baldor 6" that has one grinding wheel and one buffing wheel.
The 8" industrial grinder I have is getting ready for a new pedestal stand and is awaiting a new phase converter (3 phase motor).
All three were auction buys...
I also have a vintage 8" belt sander.
One thing you'll find is the size of the housing has little to do with the size of the motor's armature when buying offshore grinders. Most of the housing is empty while a quality motor will be filled with windings. The average Chi-Com grinder is probably half the advertised HP. If you want 1/4 HP buy a 1/2 HP to be safe.
Bolster
Mexifornia
Once you have a bench grinder, you'll wonder how you got along with out one...
Hey hey! The Baldor king!! Top of the line and nothing less, I guess. And is that one of those Garrett Wade / Lee Neilsen / Veritas ... what do you call them... tool rest under one of them?
Schweet setup. :bowdown:
steve01
Lake,MI
I got 1 of the Clark 6" from TSC. It works good and has enough power for the stuff i do (mower blades, sharpening screw drivers and drill bits) Was only 39.00 and is 1/2 horse. You will need to get a wheel dresser if you don't have 1, mine had a vibration when i first started it up and would dance across the floor on it's stand. Dressing the wheels stopped that.
Autoguy
Riyadh/Saudi Arabia
I have two, I like Baldor grinders more than Black and Decker.:thumbup:
Tim Cowan
Piedmont,Alabama 36272
AUTOGUY.......What is the red Proto box in the background wall above red grinder? I have 2 6" C-Man bench grinders and use the wire brush more than the stone. I use a vise a 9" hand held body grinder for ower blades. I would like to add motor and twin buffing wheels to my shop......
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
A vise and a 4 1/2" angle grinder, at home for lawnmower blades. I have a Orion made Craftsman, that I have a multitool on as well as a wire wheel. I always thought a sander would be more useful, until I find a good old bench grinder.
Autoguy
Riyadh/Saudi Arabia
It is a 1/2 30-150 ft/lb proto torque wrench click type plastic box.
garfunkle24
Saskatoon, Canada
A water filter hey? Thanks for doing your part for those Canadian stereotypes:thumbup:
But seriously, you could have one inside a cheapy Princess Auto blast cabinet.
metal1313
clinton NJ
i just use a good 4&1/2'' grinder, good course wheel and then a flap wheel. mower blades arent that hard, so they sharpen easy, and dull easy. i hit my blade ever few weeks, because i mow 6 large lawns with a 26" mower and sharper is better
