Spalted beech live edge table
brianh
grahamsville NY
I am working on this table in between commission jobs, I have a few boards of spalted beech I milled a few years ago this design popped in my head over the weekend.
The mortise and tenon I cut on the cnc router.
Hope to get it finished by next week in between the other work.
brianh
grahamsville NY
Its a simple chainsaw mill I can mill logs in remote spots and load my truck plank by plank.
Its good for specialty milling. A high HP saw and milling chain ground to 10 degrees or less and its quick work.
curtrnev
Man I love the grain on the feet of the legs . What part of the tree was that from ?
turbowoodworker
Apex NC
Are those wedged tenons?
I would be careful there as they are running with the grain. Most of the time I (and others) put them cross grain to avoud splitting the top.
brianh
grahamsville NY
Most of the time I do too, this design did not have room for that You just don't use a sledge hammer to put them in and its fine.
brianh
grahamsville NY
How do you keep the board from twisting, bowing, cupping, etc??
I kiln dry my wood after milling down to 8-9 percent moisture, whatever twisting and warping will happen while drying. A lot of twisted wood is from drying to fast or not sealing the ends before going into the kiln.
I flatten the boards by either surfacing on the CNC router or using my planer with a sled with shims to hold the stock as it goes through.
brianh
grahamsville NY
Its in an art gallery for the next month as a pedestal for a chainsaw carving I did back in 2007 when I started carving. any Luck they will both sell though galleries usually just get me exposure.
