Air compressor...guard or NO guard
90zcar
Just curious how many people took their guard off due to rattling noise or just don't have it anymore. I took mine off to do adjustments on the belt and deciding whether or not I wanna put it back on
rsanter
visalia ca
The guard is to not only keep people's dingers out of the belts and pullies but also things that may fall and hit it and get caught up in the works.
If you do not have a concern that that could happen then leave it off
Bob
Charles (in GA)
50 mi south of Atlanta
My old portable is so old, it came without a guard. It was an accessory I think, not sure (I bought the compressor new in about '70 or so) I'm the only one who ever uses is and usually to put a head charge on a well tank or some such, so its not like its used where children or stupid people are running around it :willy_nil
jrobb316
WI
My compressor I bought with only one piece of the guard. Its in the corner and the pulleys are against the wall so i'm not worried.
PJNJ
Iowa
Bob
Man that brings back memories. Years ago my brother-in-law bought an old small compressor at a weekend yard sale. He liked it but it was rusty, the outlet pipe leaked, one of the wheels was broken, needed a handle, etc.
He brought it over to me to see what I thought. So I did him a favor and cleaned it up, painted it, new wheels, bent a handle from soft conduit and put a steering wheel wrap I had laying around on the handle, new wheels, pressure gauge and belt. The next weekend he came over to get it. He couldn't get over the difference. We went into the garage, I plugged it, he stepped back without looking into a long handled push broom. The broom fell forward into the %$##$$^^% compressor. The belt caught it and pulled the end between the belt and the pulley and bent the pulley. It hadn't been running for more than a minute. I couldn't have planned it better. I told him to go to Sears and buy a compressor. End of that story.
zkling
Bob
Yep
I made an expanded metal guard for mine. Actually out of a piece of that white wire shelving. With my luck a piece of stock or the like would end up between the belts and the pulleys causing much $ in damage.
Monkey Milk
Hawaii
If a machine that starts automatically while unattended and has movable parts, it will get a guard.
GirchyGirchy
Central Indiana
Bob
If you're letting your dinger get that close to an air compressor pulley then you need to keep it in your pants.
fatfillup
Finksburg, Md
I too have an old compressor that never had a guard. It is unplugged when not in use and is not used that much. Pulleys are up against the wall. If I had children around, I would worry. I don't and access to it is difficult.
That said, if it had a guard that rattled, I would tend to fix the rattle sooner or later. Inner tube rubber cut to washer size, maybe doubled over, and put on the guard mounting bolts. Minimal time and I always have some rubber scraps in a box for such occasions.
