Error code: " pressure switch stuck closed "
Jaguar Fan
Park City for Ski Season; Las Vegas for Poker Seas
My air conditioner doesn't turn on. Actually by that I mean the blower doesn't turn on. The circuit board has only one error code in its memory:
Is this likely just an indicator that something else is wrong? Or is it likely the pressure switch itself?
Showkey
"MEMBER EMERITUS"
Wausau WI
Does the pressure switch have a Rubber hose attached ? Careful inspection of the hose might find it rotted, blocked, split etcetera.....?? Since it stuck closed ( if it's a normally open switch) it more likely the switch is failed. You could disconnect it as a test. Also could be checked with hand held meter.
bonneyman
Desert SW
Good advice!
