jeff5295
I would not even bother hooking that setup into your system!
You need to STOP and insulate. Then install 2-3x as much radiant tubing. You only get one shot at doing this right. Honestly, whoever did that does not know what they are doing and is just taking your money for shoddy work.
Tim
Tim, If I understand the thread, this isn't his system, but one that a builder did in his area for example.
You definately do not want that guy doing your floor.
I can't believe he would actually share that picture with you. It just proves that he either truly knows nothing about radiant heat, or he believes that you know absolutely nothing and can B.S. you into thinking this is proper. Don't let him fool you into using the "bubble wrap" foil insulation either. It's worthless under a slab. You absolutely need some type of high density foam insulation or don't even bother putting the tubing in.
Do a little research to educate yourself. There's plenty of websites with great info on the subject. That's how I figured mine out. It's not rocket science, but there are a few basic laws that need to be followed or you're wasting your time.
I don't recall the websites I used, but I'm sure others can chime in with some links.
Do yourself a favor and get rid of this "contractor".
