I'm working on the front inner structure of a 1969 BMW 2002. The sunroof drains for these cars were notorious for emptying into the fenders so there is often a lot of rust in there.
I'm cleaning mine out, and am in the process of cutting out bad sheets and cleaning off what might be able to be saved. I am having trouble cleaning out some of the deeper pits.
I started with a wire wheel on an angle grinder, switched to 80 grit roloc sanding discs. This wasn't course enough so I hit it with some naval jelly. After that it looked like pictures 1 and 2.
Part of my problem with the 80 grit was that at some point it was like I was just polishing the rust. So I got some 36 grit and tried again - it came out better, but I am trying to get as close to bare metal as possible. See picture 3 for the last results.
Should I be switching out between sanding and wire wheeling? Stronger acid or more naval jelly. More persistence?
And FYI, a lot of the metal in these pictures will be replaced - I'm waiting on the panels and figured it would be a good area to practice in.
Thanks,
Bruce
Thanks,
Bruce
