Sandblaster
Scottishross
A have brought a sand blaster off the net
It's ok but inside it goes really dusty and u can't see anything
Is it possible u can just attach a normal Hoover
Bobf
Poway, CA
The quick answer is yes, but do a search on here as the subject has been covered well.
jstroede
Kansas City
I have been using a craftsman vacuum directly on mine for almost 15 years and it just won't die. I have only replaced the filter one time. I just blow it out and keep going.
John
Sent from my XT1254 using Tapatalk
bdk1976
Hit a few garage/estate sales. I see shop vacs for cheap all the time....like less than $10 each cheap.
djjsr
In the cornfields
I use a ShopVac with a bag in it. Seems to work pretty good. I leave the back port of the cabinet open to let air in.
Vegaman_Dan
Pacific, WA
One thing that will control a lot of the dust from the media blaster is sealing all the seams of the main body. The unit you have there will leak from most of the seams as the foam tape is compressed, dries, and shrinks over time. Adding more foam weatherstripping to the door will help a lot also.
There are a lot of threads on media blasting cabinets, with good build threads as well. It's worth searching for them both here and even on YouTube.
Grizz1963
Rochester, KENT. UK
Nice work.
Having that blue vacuum with the big eyes looking back at me from under the cabinet would creep me out.
That's a Henry........ They are the UK's answer to industrial needs but reasonable pricing.
I will be building something as well know as the dust is really bad once you get going.
Chaznsc
SC
What media are you using? I use black abrasive from HF and it isnt as dusty, at least in my box.
PCO6
Newmarket, Ontario
Are you using another water trap at the exhaust of the vacuum canister.
No, just the one. The round bucket is the water trap. If you're referring to the square bucket without a lid that's just a catch can to collect media out of the hopper of bottom of the cabinet.
