Seeking Advice (Pics)
PearlWhiteGT
South Texas
I just bought a new house & not sure what to do with the garage. I want to fit 2 cars in there when ever I need to. I plan on doing a lot of work on my car.
I want to paint the walls to give it a better look. Thinking of White trim with Grey on the bottom half, 3" White stripe then 4" Red stripe, 2" White stripe & 2.5" Black stripe with White on the rest of the wall. Also plan on painting the door grey too.
Might be a little confusing so maybe this will help.
Grey - 3.5 feet
White - 3"
Red - 4"
White - 2"
Black - 2.5"
Would this look good?
Cholleman
you've got a lot of potential there. for the stripes, i think it would look too busy. if you're going to two-tone the walls, i'd choose two colors max for the stripes. check out the two car garage thread in the gallery forum for more ideas. good luck.
Tech Guy
Ontario Canada
Buy one of those paint software programs. You take your digital shots and import them into the software. Pick a colour and touch the part of the picture you want to paint with the mouse and it changes the colour for you and lets you see what it will look like with different colours. I think the software is about $20.00 at the big box stores.
P
PearlWhiteGT
South Texas
I bought one from lowes & it didn't work very well. What if I just did Grey, Red & Black with the top half White & White trim???
boiler7904
NW IN
You're plan sounds a little busy. I'd eliminate the white stripes between the gray and red and then again between the red and black. You're also going to want to make sure how tall things are that go against the walls. No point going through all of the work to paint stripes and then have them hidden. I'd also consider where electrical receptacles and switches fall. Stripes don't look good when interupted by them. You may need to raise or lower the stripes and adjust the width a little. A laser level will be your friend when laying out the paint.
boiler7904
NW IN
Doesn't really matter as long as they aren't in the stripe and you consider toolboxes, cabinets, etc. that will be up against the walls. Seems like you might want to go above the receptacles in your case. Depending on the color gray you go with, you could switch the receptacles to gray, tint the paint to match, and have the them disappear or maybe go black.
P
PearlWhiteGT
South Texas
If I go with just the grey, red & black what size stripes would look good? Thinking of 4" red stripes above the grey & 2.5" black stripes above the red.
boiler7904
NW IN
Experiment with your design in a corner or on scrap material until you like the layout.
P
PearlWhiteGT
South Texas
I need some ideas on where to build a 6 foot work bench. I also plan on getting a couple of cabinets from home depot to hang on the wall. Where do you guys think I should build the bench? I want to be able to park 2 cars in there still.
GeorgiaHybrid
Extreme NW Georgia
Have you given any thought to leaving the walls white and adding a three stripe pattern? 1.5" black, 4" red and another 1.5" black for some contrast? You could also use a light gray for the walls instead of white and then use a white trim.
CycloneISU
Ankney, IA
There is mine I went with three colors. I don't think that its to busy but then again I made it to what I like.
mikeyr
Santa Barbara, CA
Don't spend money on junk software to "test" this, take your first pic and photoshop it.
*** less than 1 minute in Photoshop...so not very well done but gives an idea. ***
e-tek
Saskatoon, SK
But not everyone is as adept as you are mikeyr!! I do love a blank canvass though - can't wait to redo mine next month now.
P
PearlWhiteGT
South Texas
Thanks "mikeyr" for the photshop. I'm still not sure what I plan on doing with the walls yet. I thought about doing away with the white stripes & just used grey, red & black with white on the top half & trim.
