CastleBravo
I need some information and some suggestions. I bought this Toledo 00 pipe vise yesterday. As you can see I was able to get all the parts off.
EXCEPT one.
Does anyone know what this second shaft is for? (No off color puns, please.) It seems to be a depth stop. Can you give me suggestions for removing the nut? I have tried WD 40, heat, boxed end wrench, and a socket with breaker bar. I even tried turning it upside down and putting the nut in another vise then trying to turn the main body of the pipe vise. You can see that the nut has begun to round over so I thought I'd better ask for suggestions before it gets too round. It might not show up in these photos but the upper pipe jaw is threaded onto the the bottom of the shaft. It turns but there is not enough room to swing it completely around so it can't be removed until the shaft turns. Did I buy a $5 paperweight?
Morning. Looking at how closely the threads and that lip on the nut match, I don't think it is actually a nut. Maybe one machined part?
Also it looks more like it is intended to help distribute pressure on the long axis of the pipe rather than a depth gauge. I say this because of the way the piece is tied into the other shaft on the right. As you raise or lower the one, the other should follow suit.
Just a thought.
they can't bite you from the top...
