The VISES of Garage Journal
jakemac
New England
I found a Reed 103 this morning for $20 at an otherwise disappointing sale. It was the only thing worth taking home.
Under the brush-bomb paint job, it's in good shape. Just a small chip in the dynamic jaw and some minor slop in the screw. There's a small bend in the handle, easily fixed with a BFH. The jaws are somewhat smoothed out from use, but they were never sharp to begin with. Otherwise they're in good shape.
It will be some time before I can get to work on it, but it will be a nice little clamper when I do. For now, into the pile it goes.
For those of you making handles, the last two pictures show how the balls were attached to the handle. Both ends were done the same.
bagged89s10
CT
Do you think parker 974s were this color from the factory?
Short time in the etank fully assembled yesterday took everything off except that little paint. I threw it back in for final cleanup.
drivesitfar
Hemi: you can always PM one of us or put up a question in the vise repair 101 thread if you are about to drill into a vise before you do. i like McB's reason for those pins and i also thought it was holding my first swivel jaw in place and it was only rusted in place from not being moved in almost 100 years. some of the old guys didn't ever use the swivel jaw and some that owned them for 50 years or more didn't know they swiveled at all.
as far as the pin you might get lucky by taking a small bolt and pushing the pin out from down below. if it's stuck spray some Kroil or PB on it and let it soak and try again. Getridofone made a little nut and bolt sort of press to pop them out from down below up and out and he posted pictures on the 101 thread or maybe he'll post it again here.
Fretters: do tell why you decided on SHOE POLISH? is it dry to the touch? looks great in my opinion. i just saw your explanation so if you already said all you wanted to i'm good with that. or if you have more i'm all ears. cool looking vise and maybe a good working one too. easy to get CHUFFED about that vice. congrats
bagged89s10
CT
Cheers chaps. :) I was half expecting a look of condemnation over that finish. :D No tea was involved CW. :D
The finish is merely plain old shoe polish. More specifically, two coats of dark tan followed by a coat of black and finished with a coat of neutral. Each coat was given around half hour to one hour to harden, and then buffed with a brush and cloth. All bright & machined surfaces were given a coat of neutral.
Been meaning to try this method of finishing for a good while now, to see whether it would work or not, and this BB seemed the prime candidate. Neither burgundy nor linseed oil took my fancy for this one, (they just didn't seem appropriate in my minds eye, somehow), so decided to try for an aged look, (hence the various colours used), with the polish.
I'm in the land of eternal damp. :D It should hopefully be quite well protected against rust with the wax though.
The whole swivel & tilt thing being incorporated within the vice itself is nice on these. 4" jaws too. It's getting hold of these which is the surprisingly awkward part though. It's taken me around three or four years to get a hold of one. For a small vice, they do seem to be very few and far between. I let one slip a couple of years ago, and I've kicked myself many a time for doing so. I'm chuffed as punch that I've finally managed to get a hold of one. If Fraggles hadn't given me a heads up, :) I'd have never even seen this one.
What problem are you having when you try electrolysis? Sounds like you've been extremely unlucky with it upto just.
It is in pretty decent nick. There are nicks and dents, but fortunately the paint wasn't hiding a multitude of sins. The rust seems to have come of awfully well too. I had expected a bit more surface pitting when it was derusted. It seems to have been slightly thicker than just a surface layer, but the metal underneath seems surprisingly untouched in relation to the rust thickness.
The thread appears to be standard 3/16" BSW, but the head is a thin taper. Can't recall the angle offhand. I do have one countersink with the same angle as far as I can tell, so I'll check the angle later. :) The heads were completely destroyed in removing the screws, unfortunately.
Shoe polish? I would never have guessed correctly. You might have posted it but do you have a before picture?
drivesitfar
Jake: i like the Reed 103 and you know you didn't pay too much for it so i don't have to tell you. might be a good one to mount on the other end of your bench or a tool box.
Sandman: so you have 3 Prentiss 58's? Holland's 18 and if you want to say or post pictures of the other 8's and 7's that's ok with me and probably the rest of the guys too.
Duo: your old Diamond vise isn't common, but i have seen a couple other members here that own one so maybe they can chime in and tell you or post pictures of what you are missing.
good luck and i probably like the history of your vise more than the vise.
Bagged: he did post before pictures a few days ago because it was green and pink i think. if you still can't find them since this thread moves fast maybe Fretters can post a couple before and after pics in the same post.
jreb10
Westby, WI
Here's another Diamond vise someone sold recently on eBay. I noticed that his has the original spindle handle. Ours does not. My Brother said he remembered our vise having one, but there's no telling why it's missing. Dad stuck an old military antenna guy stake through the spindle head to use as a handle and that's all I ever remember it having.
If you look at the bottom picture, you can see the flat spring under the static jaw. This is the part I'll need.
Btw, does anyone know how the vise spindle handles were constructed? I don't know if the knob on one end was swaged on and the other threaded, or both were threaded or what. I'd love to find a proper handle for my vise eventually.
Well, well Duo. That was me that sold the Diamond vise in the pictures. Same original paint as yours.
I remember that the handle ends had a sort of metallic joint up towards the top end of the ball. You can barely see it in the pictures you posted.
I did find a couple of other photos from the refurb of that vise, that perhaps show it better:
Someone more knowledgeable than me may be able to say how they balls were attached. I would hazard a guess that they were peened over, but that is just a guess.
timbitca
Moncton, NB, Canada
Alright my bunch of Vise experts, who can identify this?
Might go check this first one out tommorow. He's also got the post vise for sale and the old wooden vise also.
Love the looks of the post vise, but unless he makes me a killer deal it's staying there, I've got one back home and I've unfortunately got 1) no room and 2) zero use for one in my current shop. Sort of anxious to be able to see this one though, as it appears identical to mine, see if I can make out any markings on it because I can't make out anything on mine.
TIMBITCA: Just the man I wanted to speak to. Thanks to you I now own a second pipe vise and I didn't even have a use for the first one. I was rooting around an old shed at a garage sale and I came across a rusty pipe vise which I promptly ignored. When I couldn't find a proper bench vise I came back to have a closer look at the pipe vise. Lo-and-behold it's an RAE. Until you posted those pictures of your beauty I didn't know that name. Now I have two pipe vises. This one only set me back $2 US though. I just took some BEFORE pix that I'll show along with the AFTER pix whenever that is.
Glad that you can blame me for you buying stuff, I keep blaming everyone else on here whenever my girlfriend mentions something ;) I think sometimes she wishes I hadn't gotten the full time job and was still only working part time and not buying seemingly every tool I come across (that's what she thinks I do anyways haha)
drivesitfar
Tim: that Blacksmith vise is one of the few i'd like to own. it has great lines and it's built stout. depending on how heavy or how wide the jaws are would determine the price i or you might want to pay. it does look like a keeper though.
the double swiveler looks like a cheap import and missing parts. some of those are built a lot better and like I've said I have yet to meet an owner that didn't like using theirs.
timbitca
Moncton, NB, Canada
The blacksmith vise looks almost exactly like the one I have in my garage back home. This one is mine:
View media item 26564
That was my gut feeling on the double swiveler also. Might still pop in to see what he's got if the sales don't look promising tommorow, seems to have a few interesting ad's on Kijiji.
topop101
NW Missouri
Very well could be Bagged, Here's one I have, baby blue.
Fretters
South Yorkshire, England
DIF: No reason bar pure and simple curiosity as to how well it would apply, fare over time and also look. Wax is a good barrier against moisture, so it should be a usable finish, and easily reapplied if necessary, so there's only one way to ultimately find out as to whether it's feasible.
Once it's buffed up, it's quite dry to the touch. It only has a tacky, waxy feel when first applied. Once buffed, that disappears.
I posted some a day or two ago, but here's a few of Precious, (I still think they're taking the piss as to why they gave it that name, but it's growing on me :D), again. :)
Before:
guimage
guimage
guimage
Derusted:
guimage
guimage
guimage
CRSINMICH
Southeastern Michigan
TIMBITCA Here are the before and after pix of the RAE N0.71 pipe vise.I decided to clean and lube it only. I think I'll try FRETTERS' clear wax finish idea. This was a fun one day job. In fact, I've only owned it for 24 hours. Did RAE paint many of their vises Sky Blue?
schor
Ajax, Ontario
Spent a bit of time on this vise.
Ll25Ip6ilnRF1pnWWrWo1jgjE7I5EXrQaYQrZ8jTyRs=w391-h220-no
Cleaned it up a bit
7i1nuGRt8Hm_61NI9qiZHEn_0-EYBAQc3r9Cjsz0TtY=w1264-h711-no
Some black paint.
xc0XXiHMJU5lKXcUgTYdJuHSWhnhIq6Nq7YLmEFRNmA=w1264-h711-no
And some old school flames.
wPmzFNUGBJvB1z44coypqp049knDT3UnOJgCNzPm2Lw=w1264-h711-no
Need to finish it up when I get home from vacation.
Fretters
The Woden 186E/8 I got the other month is all abouts done now too. Just needs new bolts for the inserts and a broken bolt tip removing from one of the inserts.
Before:
guimage
guimage
Current:
guimage
guimage
guimage
duojet55
Van Buren, Arkansas
Jreb, that was a sweet example of the Adams vise! Thanks for the info on the handle. I'd never realized that there was so much interest in old vises. In fact, until recently, I hadn't really thought about them having any collectability. I knew it was ancient, having belonged to my WWI vet Grandfather, but to us it was just a working tool. Thanks to all of you guys here I've come to appreciate it on another level. I'm going to give this old workhorse a well-deserved refurb!
bobcatdan
Kaukauna,WI
I got my new broken Morgan to my buddy's weld shop for repair. He was very surprised that it was a big 6 inchers. He seriously wants to buy it from me as he feels it would be great for his shop. I'm undecided with vise because I didn't have a good place to put it. I'm thinking very hard about a pedestal, but I don't have a great spot for that either. Once I get the vise back so I dont have to guess it's size, I'm going to play around with all my options. I've been playing with the idea of swivel pedestal, once again, need a spot to use it.
tshetter
Central, FL
I wouldn't mind betting that picture was taken with a mobile phone, that's some pretty impressive lens distortion ..... or perhaps a tapered bench as well ;)
Photo was taken with a phone at an angle. The bench may be sloped as well. Needs to be rebuilt stronger and with a thicker top.
bluebolt
Benton LA
Here is my Wilton vise made in August 1946.
Just picked it up for free at a garage sale.
The jaws measure 4 1/2" across. What number vise is this? Are replacement jaws available?
It has been used, but it locks up tight, very tight. No noticeable slop. The grease on the threads sure does stink!
Nice score! I will add it to the Bullet date database.
bluebolt
Benton LA
To find a vise you have to follow the crumbs! At an estate sale today I found a single slip on pipe jaw for a bench vise. No vise anywhere I figured it was gone already. I asked the young man watching the garage if he had seen a vise. He hesitated for a minute and then said it was in the back behind a door on a workbench and he didn't have any tools to get it off. He let me in and I found a nice little Columbian No. 43 open screw vise. Not only did it have the other pipe jaw but the little cutter for the anvil area as well! I went and got my tool kit and removed it. It's in nice shape, straight handle and all that.
Bricago
Chicago
I posted last summer about a Craftsman vise... it is the larger 4" #5169... A couple of notes on design and assembly...
I'm trying to disassemble a 5169. Do you happen to know how or whether this pin is removed? It "pins" the main screw nut inside the static jaw.
Thanks for your help.
drivesitfar
Bric: that is just a pin and they can usually be punched out from below. you can squirt on a little kroil or WD and give it a few light taps and it should come out. you will need to remove the swivel base to see the bottom of the pin if you have one or haven't done that already. good luck
TOP: before you sell another dozen or so vises how about a family picture? nice looking baby on that power arm and Kevin's jaws really make it shine to further enhance your work.
JZiggy
Atlanta
Just stunning. If I ever wear out the current jaws on my Paramo, I know exactly what I want to replace them with...
My original jaws are in OK shape but they have such a light texture. These Wilton-style jaws have nice deep serrations.
