HF Tire changer storage
Outlander
Quebec, Canada
I have read all the threads, seen the trailer hitch mounts and have decided to install mine on a pallet. However, I do not have room to store it inside the garage, so it will end up outside, probably under the deck.
Covering it with plastic tarp can be accomplished...but....will it end up a rusty pole after the winter?
How about any 'quick connect' ideas? I don't / won't use it too often so maybe just biting the bullet and bolting it to the pallet when I need it is the best idea.
dodge610
North Canton Ohio
Look on line for a product called fluid film and spray it down before you cover it I have had good luck with this seems to keep the corrision off most of the stuff I use it on.
Jarhead0408
Who knows?
Find a plastic 55 gallon drum, cut one end off, and use it for a cover.
Man, some days the simplest answers blow me away. My HF changer is outside too. Less than 25' away I have a plastic 55 gallon barrel that already has the end cut off. Never occurred to me to use it. Of course, that might be becAuse I've been using it as a shop can. Thanks for the idea!
