Parts Washer Pump
Binger
CHEYOMING
Hello all you in Garage Land. I tried the search function and never have any luck.
Any how I recently got a 30 gallon Harbor freight parts washer. Its the kind that sits on a barrel and the pump hangs on a piece that hangs down in the solvent. The machine was new and I used it only about 45 minutes and the pump quit working. I havent taken it apart yet and maybe I can fix it once I get it apart.
What I was wondering is what is a good replacement pump for this unit? I havwe seen some on line but was wondering about a good one to buy and things to look for in a new one.
Thanks in Advance.
John Binger
dodge610
North Canton Ohio
HF if you still have your reciept and it isnt that old should warranty the pump. Give there Customer service a call they will probably send you a new pump. There CS people are great they should fix you right up.
Binger
CHEYOMING
The washer was given to me by my brother who picked it up over 5 years ago. He never used it and gave it to me. I was a little sad after it quit mid way through taking apart a rear end for my model A.
Binger
CHEYOMING
I bought cleaning solvent from a local Oil company. Perhaps the pump wasnt set up for a petroleum based cleaner?
dodge610
North Canton Ohio
Even Tho its 5 years old you should still be able to get a new pump from HF customer service. Granted you will have to buy it but HF has improved a lot of there products call them and explain the situation I am sure they can help you out. Never know they might have been getting calls about that pump all along. Its worth a try.
Binger
CHEYOMING
Thanks for the info. The nearest HF is 50 miles away. Will be headed down that way over the weekend and I may stop in and see what they have to say. I saw a pump on Home Depot site that is only about $25 bucks. They also listed a $40 dollar one. Wondering about quality of both. Hard to tell from the pics.
dodge610
North Canton Ohio
If they know you at the HF they might hook you up. I know the manager and asst, manager at mine they usually pull strings to help out.
Packard V8
Spokane, WA
And if they don't know you and/or are like the employees at my local HF, all you get is a blank look and "We don't have any parts here or any way to find them. Mebbe, try an on-line search or call our customer service 800 number."
I've got a several-years-old HF air-over-hydraulic pump and there's no number stamped on it and whatever stick-on label is long gone. They looked at it and said, "The new one is different. Dunno if there's parts. Call customer service."
jack vines
Binger
CHEYOMING
HF has two pumps, one for aqueous solvents and the other for petroleum-based stuff such as spirits etc.
I wonder if I have the aqueous solvent pump and killed it with my petroleum based solvent I put in it. when looking for a replacement I will make sure I get the right one.
