High flow air couplers
CRXPilot
west TX
When I worked in a local auto repair shop I bought a Mac awp050 to replace my dead Kobalt impact. Shop air ran it great of course. I wasn't aware of different air coupler types at the time and am still running cheapy harbor freight 1/4" stuff.
Now that I'm at home, semi pro and working with a tiny oilless compressor its noticeably slower. My question is will high flow fittings like Wilton v style get me any extra performance or will i need to move up to a bigger compressor to see any change?
lightning02
I noticed a big difference when I changed everything over to high flow plugs and couplers from the junk I was using before that. But you also want to make sure your compressor is set so that the tool is seeing the psi it required at the tool when it's in use.
L.Cheapo
I was using 1/4" hose (USA) and HF couplers that I bought in a pinch. My IR impact struggled to take the lugnuts off my Ram 1500. Sometimes it couldn't. Anemic comes to mind.
Then I bought a 3/8" Flexzilla hose and Milton 1/4" Hi-Flo couplers and they changed my life. That same impact, with the same input PSI blasts those same lugnuts off instantaneously. Holding a Milton Hi-Flo next to the HF couplers is a very obvious difference. I'd say at least twice the size.
And if your HF couplers aren't leaking yet, they will. Or they'll jam and spray high pressure air when you don't want them to. Ask me how I know.:mad:
Edit: Its worth mentioning that you can likely still use your standard flow fittings with the Hi-Flo couplers. I kept the smaller fittings on the blow guns, etc. Also, when inserting a Milton Hi-Flow fitting into a Hi-Flo coupler...there's no need to retract the coupler. It just pushes in. No leaks. Very nice. Buy them.
sberry
Brethren, Michigan
It was the hose not the couple causing problems. or the OP, you were using a good air supply and changed. A better couper will not help that.
On-Wheel
Don't use 1/4 anything . Use 3/8 hose,3/8 fittings.Longer hose used more pressure needed.
With a 1oo foot hose you'll need 120 psi at regulator to get 90psi at gun.
50 footer ,maybe 105 to get 90 at gun.
Using 1/4 fittings you need more psi ,PERIOD
I heard cheap 3/8 hose now has 1/4 restrictions in fittings.About as lame as reading bar codes to see where food came from.Instead of saying where from not where it was packaged.
The vid I found shows in detail below,numbers above were guestimations.
Aerogt01
Something nobody tends to think of -
I'm convinced the regulators on pancake and other jobsite compressors cannot keep up with a high intantaneous or especially continuous demand. I used to have an extra off a compressor. Those things are TINY. There is no way they flow well. This is supported by my experience with 3 different small portable compressors - HF, Porter Cable, and Ridgid.
I have been able to get an impact to work on a Porter Cable, but only get 200 ft/lbs max out of it and can't do a whole wheel before the compressor kicks in.
I would spring for a bigger compressor. I don't think fittings will help a bunch.
firebox40dash5
I've posted yhe same theory here and several members insisted those tiny buggers could flow 80cfm no problem, and running air tools on full tank pressure would be the end of the world... oh well, I still agree with you.
I get surprising performance out of my 120v 20 gallon rollaround. Before I ever fired it up, I pulled all the plumbing from the tank, and upped the 1/4" stem to the pressure switch with a 3/8" tee, with a 3/8" shutoff valve straight to a 3/8" coupler. The pressure switch outlet got the factory 1/4" regulator, and matching valve and coupler, in case I want regulated pressure.
Milton V fittings definitely help, but only if there aren't other bottlenecks. Otherwise you're pretty much just exhausting the pressure in the hose faster. Take a look at what's between the tank and the hose and see if you need to free that up... it's a cheap try, and if you still end up wanting to go bigger, you can take the parts back off and use (most of) them on the next one.
Aerogt01
While I may not be convinced to run my tools at tank pressure (or I have yet to find a nut rusty enough), I have considered a similar system with a true full-flow reg more than a handful of times.
90zcar
I get whatever the 1/4" fittings are off the snap on truck. I use a 60 gallon compressor and 3/8 flexzilla air hose....no problems here
Someone told me tho that the Milton high flow couplers work with the normal fittings that I have. If that's the case and I wouldn't have to convert everything over...I may look into this for my impact gun. Where/what is the cheapest way of obtaining these?
Mass
One fix for the flow problem is an extra tank between the gun, and the pressure regulator on the compressor. This extra tank will provide an unrestricted supply for short bursts. Will be more effective if the hose between the gun and new tank is short.
Might use a portable air tank, or an empty unused propane tank with a Tee for this purpose.
dnschmidt
Phoenix, AZ
The cheapest source of Milton V's is JBtoolsales.com. The Milton V coupler will enable the use of the normal M and TruFlate stems but they leak. They work, but they leak. They are simply too small to fit the hole in the V coupler.
Don't get the idea that the V coupler and plugs will make up for an undersized compressor. That ain't going to happen.
uglyjacko
Mexico
I use the larger ID HF fittings as well. I have a few others fittings in the air system that I have bored out to the same ID as well. They work, but eventually the couplers begin to leak (about a year)
No leaks on mine after 8 months of using them, also I have compare them to the milton hi flo V, the HF has a bigger ID of .308 vs milton V ID of .275
99LeCouch
Rochester, NY
Milton V-style couplers made my cheapy Craftsman composite 1/2" impact run noticeably better. Upgrading was cheap, about $20.
For whoever said to check the rest of the system for bottlenecks, that's one that will happen sometime this winter when I need a project to get out of the wife's hair.
hangfirew8
Central Maryland
If you're running 1/4" hose, moving up to 3/8 hose (with 1/4" NPT fittings) will help.
If you have a constricted system, usually the quick connect is the main suspect, and high volume fittings will help. What you'll find is the tool will work well for a few moments and then your tank will need refilling and you'll wait. That is OK.
Here's a pic, I went with GuardAir High Flows, they are compatible with standard fittings such as the one seen in the pic. If I had to do it over again I'd go with Milton V's because they are cheaper and more than good enough.
3/8 hose has 1/4" NPT fittings, which is more than OK for all air tools rated for 3/8" hose use, such as any 1/2" drive impact ever made.
ovrrdrive
Central Florida
Interesting pic... This is of the HF large connector and I measured it at .30" ID as well. The rusty one (bottom of the drawer) beside it is one of their run of the mill variety and I measured it at .18" ID. Their 1/4" x 3/8" connectors are a little more expensive but I think they're worth it. they're also compatible with the 1/4" x 3/8" connectors at HD and Lowes too as I've bought from all interchangeably.
I didn't price guardair but I bet they are quite a bit more.
90zcar
So those 2 different ends shown above can share the same coupler?
hangfirew8
Central Maryland
I was impressed that a swivel nickled automotive male from Lowes worked in my GuardAir High Flow quick connect without leaking. That is about the extent of my compatibility testing.
-HF
uglyjacko
Mexico
They're not expensive at all! They are the cheapest for hi flo 1/4 npt coupler set you can buy anywhere, the only other 1/4 npt coupler & plug that comes close to it in price & performance is milton hi flo V
RAYJAY
UNION DALE PA
your problem is in red ..... buy a real air compressor
90zcar
I want to get a clear answer on this. If I get this style coupler
And these *******
Will my original ******* work on the high flow couplers aswell?
Olafur
Iceland
Agreed.
On smaller compressors the regulator is THE great bottleneck for airflow.
tshetter
Central, FL
Anyone?
Yes.
I use Milton Type-V high flow couplers on all my hoses and Milton fittings on my demanding tools.
My non-demanding tools are standard I/M fittings from Lowes and Harbor Freight.
The I/M plugs fit into the Milton Type-V couplers with no problem.
90zcar
Awesome!! Thank u very much. Now I can be at ease ordering some!
lightning02
You can get them at northern tools as well. That's where I buy mine since it's only 5mins from my house.
90zcar
Got them today from my local air supply store. Will test them tomorrow
Old vs new
90zcar
HOLY ****!!! that's all I got to say. I had the air compressor running and used my impact today. I'm not kidding when I say I just pulled the trigger and let it free spin and even felt a difference!! Wow. I am very satisfied with my purchase.
Also have to add that I can simply just push them into the coupler. I don't need to pull the sleeve back to install them. Also my old industry standard ******* that I have on everything else work perfect with the new couplers so I don't need to convert everything to the high flow *******.
Best $26 bucks I spent in awhile
lightning02
Yeah thanks for your help
No problem. Everyone that I recommend high flows to as felt the difference right off the bat like I did. I wish I found them sooner lol
