The VISES of Garage Journal
02superduty
LI, NY
Picked up a couple vises today. First is a Prentiss 19. My first swivel jaw vise. She needs a little work. It is missing the swivel pin for the jaw. Or is it called a plunger?
02superduty
LI, NY
Second is a Columbian 604. A little beat up but worth the $20 investment.
McBrownie
Cleveland, OH
Hemi49
Rush (Rochester), NY
I just finished tuning up a Prentiss 19 double swiveler.....They are a nice vise...I painted mine with Rustoleum Hammered Rosemary®.....
bagged89s10
CT
autopts
Got my CNC machine fixed again, and had some time before my next run of jaws. I tackled a Athol #79 that has casted in jaws and was built to be mounted on a bench with a clamp under neath the bench. I carved out a new swivel base and copied a Parker brake caliper set up. It's the small one on the left.
The Jaws were casted in and I want to replace them with bolt in sets. Yes it's only a 3" vise but it's a Athol and deserving of a second chance. I took my time cutting the very hard jaws with a carbide end-mill and wanted to see if I could figure out how they casted these inserts in place.
These cast jaws were 5/16 thick and once I cut that much off I seen the knit line of hard steel to cast steel and still do not have a clue how they put these hard inserts in place. So this 3" vise was a practice cutting method for me and I learned what works and what did not. Check out the pattern of hard insert to cast, the hard steel is very shinny compared to the dull cast. The hard insert looks like it was pored and running down the face of my cut pocket.
I have a few vises almost done and will share pictures when finished, I like how the Parker bases finished up and how well they lock down with just one lock down.
Kevin your work kicks *** just like Manning and crew kicks ***!!
zkling
Nice, nice...:lol_hitti. It is impossible to achieve sharp edges by hand. To do it right you need a mill or shaper. We do our best. I'm working to correct this with a new tool I picked up. We"ll see if it works.
No it's not, just use a sanding block, stone or files. You can even do it under power just have to make sure the belt/wheel/buff is leaving the edge not entering it.
topop101
NW Missouri
A couple of vise's I finished in between orders and one I picked up tonight off Cl.
bagged89s10
CT
You're right that It's not impossible, just takes practice and patients. You just have to do exactly what you said. Z, I'll get nice crisp corners for you on the next vise i'm working on. I learned a few things about sanding and filing on the Parker that I just finished.
On another note, I think everyone should have a swivel jaw vise in their shop.
The only bad thing is I bet these pins go missing a lot. Anyone have a trick way to chain the pin. I'm thinking some type of C clip like Parkers have for their swivel wrench.
CRSINMICH
Southeastern Michigan
I got these yesterday. The clamp-on was $2 at a flea market. The Erie was $20 at a private sale. (Kevin: How do you like my tablecloth?)
CRSINMICH
bagged: I'm trying to wrap up a Cman resto. Gonna try your method for making the hub and handle shiny. I don't think I'll have the patience to make it mirror-like.
jakemac
New England
Here's how the military did it on that Reed ordinance vise Joe had a few months ago.
Vantastic
Penns Woods
Got a reed 104r yesterday. It's in great shape just ugly. This one was originally grey. I think this makes 13 reeds around here.
Nuts
Baker City, Or
I have a Wilton 835 with an ear missing on the swivel base. Are replacement bases available?
Also is there a proper gray paint for early Wiltons?
Thanks Nuts
tedsters
Nice Reed
BriSco
De Soto, KS
Hi, new to this forum. I found it while researching my latest garage acquisition.
A Rock Island #574 vise.
I've since torn it down and started cleaning it.
I'll bleadblast and paint it.
The green is just overspray on all the grime.
I notice that is bright yellow inside. Could this be the original color???
KMScott
Oh boy I am hungry for fried chicken after seeing your tablecloth CRS. In my world CRS means (Cold Rolled Steel)
Thanks Nick, I wish I had more time for the fun stuff, I am always behind. I am betting this is Manning's last year.
Including how to round over edges. :thumbup: :spit: Is TriJeff also a student of yours?
Sharp edges on casting are susceptible to chipping, I like breaking the edges some, doesn't take away to much of the looks. I just machined a anvil on a Parker #22 and it had plenty of hammer chips. I will break the edges some, do you really leave sharp edges Zkling? Maybe get away with it on Wilton's since they are not beat on to much but I will round these on this C1 and Parker just a bit. I have the luxury of either milling or grinding these anvils, kind of depends on what machine is open.
jrobb316
WI
I would highly doubt yellow is the original color. Nice Rock Island, if thats your first pull at acquiring a nice vintage vise you hit a home run!
va.grouseman
Southern-Central VA.
BriSco,---Very nice Rock Island.---Perfect garage size.---Need to find you the Birtman Electric Emblem that goes where those little holes are in the side of the body, for full restore, unless it's going to be your beater.---Nice score.:thumbup:
zkling
O no, as I am sure you are well aware there is a big difference between breaking a edge and rounding an edge unevenly to the point of convexing a surface. The latter is visually hightened by a finer surface finish. I've just seen so much of it on firearms it just bothers me on anything that should have had a machined surface. Worst is when people get carried away buffing and oblong holes, engravings, etc.
At times when something is so worn there is only so much one can do. I just find it a bit sad to see something that was crip, clean and flat be restored into a wavy object.
BTW, is that anvil horn pressed in? Looks like the top of the block is cracked.
KMScott
Yes the horn is pressed in, it is not part of the casting, if it was it would not last long, and yes there is a short fracture, I still pondering what I am going to do about it. I might add a piece of heat treated S7 so to protect the anvil from further damage and make a stronger anvil like the old 2" Wilton's.
You mentioned guns, back when I was a mold welder and repairman in the 80's I welded up the action on a old Mauser and reground and fit the wore out piece where I thought it should be, the owner took my work and filed and wired wheeled the piece and told me it was too precision. That was the last time I worked on any guns.
CRSINMICH
KMScott: My mother had a funny way of naming her kids. That's not actually a tablecloth. It's a tea towel. They work so well as shop cloths that I went to an estate sale on half-priced linens day and I .....uhhh, never mind.
torqueman2002
SE Michigan
Update on the RED Parker 52.
It's out of the soup, 99% free of rust and paint.
Before.
Now.
The jaw-pin is driven out, only 1 on the fixed side. Add that to parts needed list.
The threaded 'pin' that fixes the movable-jaw on the dynamic side, turned out to be a broken bolt. The hours spent in the 'e-soup' helped rid the rust and crud that held it fast.
As it turned out, it worked loose and popped out; it was not threaded into the jaw - as I feared.
The jaw inserts took an additional trip to the CM Block wire wheeler.
The clean up revealed a couple of issues. Also, what's the purpose of the boss with small hole? It appears to align with jaw swivel-pin on the jaw's bottom. (Pictured 4 pictures above)
Maybe the missing tapered pin, allowed the jaw to move under force and broke the movable jaw's rather thin outer edges, pictured above and below.
I like the Kroil finish look, maybe I'll keep it 'naked'! :shocking:
Above - The main nut needs to be secured with a nut pin (which was missing, and probably had something to due with the negotiated price, along with the remoteness - Mexico, NY). Another part added to parts needed list.
For now, the movable jaw-pin is another bolt; until I can get a tapered pin made up. Maybe with a chain to keep it with the vise, so it doesn't wander off. I wonder if the boss with small hole, once served to tether a pin. :dunno:
The remaining parts to be found/made/adapted are the base, through bolt, and large wing nut to secure it to a bench.
Thanks for looking.
Comments and suggestions are welcome.
BFBOB
Would it serve the purpose of reducing chipping to put a 45 degree chamfer on the edges? I think it might look better; more "supposed to be that way" than a roundover. Just a thought.:dunno:
torqueman2002
SE Michigan
While the e-tank is unoccupied, I thought what's next for the treatment?
After a lot of de-greasing, this Reed 32 was readied for the tank.
Before.
Now.
Lots and lots of old grease removed, but the big parts are in the 'soup' to help with paint removal, more than e-de-rusting. There didn't seem to be a lot of that.
Thanks for looking.
Comments ans suggestions are welcome.
:thumbup:
