shoot summ
- Joined
- Jun 8, 2010
- Messages
- 2,971
I recently replaced my compressor pump, thread is here:
http://www.garagejournal.com/forum/showthread.php?t=278440
Things were going along well, compressor ran fine, had several instances running high volume tools where it performed well.
Recently I started tripping 1 leg of the circuit, my fault as I hadn't coupled the breakers. I checked the wiring, and everything was fine. I installed the correct breaker to make sure I didn't have a bad breaker.
Now I'm tripping the thermal overload on the motor. It always happens near the end of the cycle, I can cycle a couple of times, then it trips. The motor is very hot to the touch.
None of the wiring is even warm to the touch, so I don't believe I have a voltage issue although I've going to put a meter on it tonight. I'm also going to check the pressure switch contacts to insure they are good.
So my thoughts are a potential problem with the motor, or I'm just running the motor too hard and perhaps need to back the max pressure down on the switch(I'm going to try this anyway).
The motor is probably 10+ years old, and the PO had the compressor outside. The bearings feel OK with no play or drag. Could something in the motor cause the issue?
This pump will supposedly go to 200psi, I'm currently cutting it off at 150psi.
