roadrunner255
Hello all,
My 12 x 36 x 40 garage is in the process of getting formed for the foundation and slab and I ran across a thread that said a detached garage needed a grounding rod.
The previous owner prewired a PVC box enclosure on the outside of the house and main fuse panel with a 100 amp breaker and has THHN 4 gauge in the outside box.
Detached garage is only 35' from the box attached to the main house, would I still need to run a grounding rod?
If so I need to install the grounding wire before they pour the concrete.
Could I place the grounding rod in the footer (40" deep) and run the bare wire up through the concrete or do I need conduit?
Thanks in advance!
Thanks in advance!
will find out this coming week I'm calling in an inspection on my conduit
