small 1/2 ratchet
AmateurMechanic
looking for a 1/2 ratchet with the thinnest and narrowest head any suggestions
If the thinnest ratchet is what you're looking for, you can't beat a pass-through ratchet (unless you go for ratcheting wrenches, but then you lose the ability to use multiple sockets with one ratchet).
Even the thinnest standard ratchet will be much thicker than a pass-through ratchet once you put a socket on both.
Gearwrench makes a nice locking flex-head pass thru ratchet at a reasonable price:
http://www.amazon.com/dp/B000NIAKJK/?tag=atomicindus08-20
Dave455
Sussex, England
Some firms offer basically a 3/8 ratchet body with a 1/2 inch square drive (similar idea to the more common 1/4 ratchet with 3/8 drive). Think Hazet offer one. There are probably others!
Nepros have recently offered a version of their 90 tooth ratchet in 1/2 drive, which I havn't seen but has got to be pretty sleek!
Failing that, if you can wait a little, KoKen are introducing a 1/2 inch drive version of their Zeal / Z Series. I have the 3/8 ratchet, and if the 1/2 inch is as good this will be a serious contender. Matching low profile sockets will probably be helpful too!
toolaholic
PA
Armstrong, gearwrench and Matco. All apex group ratchets. Very thin heads. I use the Armstrong 12-994. Plus have the 118pc set in my trunk of my car for emergencies. It has slim 1/2 drive ratchet in set
bonneyman
Desert SW
Of the standard ratchets, I've always found the open gear head rats to be pretty minimal. Not as thin as the pass-thrus, but, bulletproof.
The new Wright open gears look especially nice.
popparoach
okc,ok
ratcheting wrench and adapter by far the thinnest ive used.
or these from harbor freight have saved my *** a few times
P
patrickw10
Sidney, ohio
thanks for the replies so far i have a passthru set was looking for a more standard ratchet. the wera has me intrigued does anybody have one to show comparisons with other ratchets. im kinda liking the wright open head also. keep the suggestions coming
