Best table for a $350 budget
My wife surprised me the other day with the news that she is pregnant with our first child.She asked me about remodeling our spare bedroom and turning it into the babies room.We have been wanting to remodel it for awhile now and its time to get started.I need to get a new table saw as my old skil brand saw just doesn't do what I need it for anymore.Its ok doing rough cuts but I need a much better saw with better features and performance.I Ned a portable saw and will be using it to rip plywood for custom shelving and making custom trim.I'm looking for recommendations on which is the best saw for $350 or less.I have already looked at the Kobalt and Porter Cable job site saws at Lowes.Its seems to me that the two are nearly identical with a $60 price difference.I'm leaning more towards the Kobalt but am open to suggestions.
jimgood
Marshall, VA
Usually what makes a table saw good is the fence. One that you don't have to fuss with. You move it to the correct distance, lock it and forget it. If the fence on the Kobalt can do that, get it. Take a tape measure to the Lowe's and fiddle with their floor model.
You also need to consider outfeed support. If you don't go with a table extension, you should get at least one roller stand.
You could also consider a jig to make long straight cuts with a circular saw. Easy to make.
Or you could just buy one.
I made several cabinets and bookcases using a jig and circular saw.
Youngguns
Mtns of Western Maryland
I support Jimgood's opinion.
A circular saw with a fence jig is the way to go, but if you're gonna get a table saw, it's all about that fence. I think the circular saw won as GJ's number 1 saw to have as a homeowner.
danski0224
Near Naperville, IL
The DeWalt DW745 consistently comes up a winner in the small portable table saw segment and it is $300.
The DeWalt DW744X is the next step up for portable table saws if yellow is the color of choice.
CTyankee
CT
What he said x 10.....
Get/make a set of horses. A skill saw with a good blade and a guide will rip plywood better and easier than you are going to do it on a portable table saw.
PBCampbell
WV
X1000, breaking down a full sheet of plywood would be far, far easier with some saw horses, a guide bar of some sort and a circular saw. I think aluminum guides can be found at the big home center stores for few dollars.
Shiftless
East Bay SFO
I like my Dewalt 745
Had it for 3 years. Nice fence...not a biesemeyer... but the saw is available new for under $300
Shiftless
East Bay SFO
How true! I don't rip anything wider than 24" on my DW745
I use a circular saw and a guide. If you have to, just lay down some scrap 2x4s on your driveway to support a full sheet of plywood, set your blade depth to the thickness of the plywood plus a quarter inch and "let 'er rip" Cut right into those 2x4s. They will support your cut on both sides and minimize the chance of binding when you cut.
8comm13
SoCal
I also would go with a circular saw and a guide. Which also frees up some extra cash for your remodel. Also congrats on the good news :beer:
jimgood
Marshall, VA
The other important thing is that a table saw takes up a lot of damn space. I have a full sized Craftsman I've had for years and when I don't need it, which is 99.9% of my life, it's just in the way or a good place to pile stuff.
WarDamnEagle
Auburn
I have a table saw but when I am building shelves out of 3/4" plywood I decide what widths I need and I get the sheets ripped at Home Depot or Lowes. I have found that fooling with full sheets of 3/4 is awkward at best. As others have said, if I was going to rip them then I would use a skill saw and saw horses. At least until I got the sheets down to half or less.
Congrats on the baby btw!
bczygan
DETROIT! Arsenal of Scrappers
Only a guy would say, "We're having a baby...........I need a new table saw!"
From the title I thought you needed a dining table, then when you said a baby was due, I thought a changing table......
R
I do have a circular saw and a homemade jig for ripping sheets down to size.I guess I should been a little more specific.The table saw will be used more for cutting the shelf boards and ripping boards down to size for trimming out doors and windows as well as doing other various things.Space isn't an issue as I have plenty of room to store a table saw.Thanks for all the input though.
R
Lol guess I should have proof read the title before posting.
Trey T
Houston, TX
I used to own a table saw 10yrs ago but that's one tool for me not to own. I would rather get a track saw because it's easier to store and safer to use. I'm just a weekend warrior, btw.
crerus75
I purchased a Ridgid from Home Depot about 10 years ago. It's a contractor saw that comes with a stand with wheels. You can pick up one end and wheel it around like a wheelbarrow. I compared it to Craftsman and Dewalt contractor saws, and I liked it the best. It's well put together, easy to use, and you can adjust the fence to be dead-nuts in most positions. It cuts pretty well with the factory fence and has decent power. I've ripped lots of wood for shelves and miscellaneous projects, I've made smooth cuts in MDF and particleboard, and I've cut aluminum plate, plastic, tile, etc. with the correct blades. I've even ripped 4x8 sheets of 3/4" plywood with it, though I'd MUCH rather use a circular saw and a guide. It's been a good saw so far. However, it's not perfect:
-It has a built-in table extension that allows you to cut over 24" wide. The extension isn't flimsy, but it flexes enough that the fence will not clamp as tightly on the extension as on the main table casting. I've had the fence move after bumping it with a piece of wood.
-The blade guard and riving knife are easy to knock out of alignment, which will either make the riving knife go out of alignment with the cut, or move the guard to where it can touch the blade. Since the guard is clear plastic, you can see every damn blade mark on it clear as day. Yup, this is experience talking.
-The miter gauge is decent, but I'd like it if it fit a bit more snugly in the channel. Granted, this is a relatively inexpensive, portable saw, but still...
-The table insert is steel. It's retained by a flathead screw and the height is adjusted with four small grub screws threaded through the insert. These can be cranked down to adjust the insert height and vice-versa. However, the steel is so thin that it flexes easily. That means that if you screw the plate down tight enough to not loosen every third or fourth cut, the steel will flex and sometimes catch the edge of the wood as it is fed through the saw. Adjustment is always a balancing act between having the leading edge stick up from the table, and having the edge flush but having the middle bow up slightly.
-I'd like to buy or make a few blank table inserts. That was I can make my own zero-clearance inserts. However, because the original is retained with a single screw and a spring clip, and because it's so thin, I don't know if I'll be able to come up with something.
-The table is aluminum and will scratch, especially if what you're cutting has an unseen/unnoticed bit of cut-off staple sticking out of it. I see that scratch every time I use the saw. Grrrrr.....
-It's LOUD. I know, I know, universal motors are always loud. Still, this thing screams like a banshee. Hearing protection is mandatory.
-No access inside the saw from the back. Changing blades means removing the table insert, which means putting it back into place later and dealing with the aforementioned alignment issues.
-The cord holder on the back is just plain stupid. It's like a fixed plastic spool with a cutout to grip the end of the cord. You're supposed to wind the power cord around it and then clip it into the cutout. The cutout doesn't hold well, and if you wind up the entire cord, it blocks you from getting to the cutout anyway. I wind up what I can and then tuck the plug out of the way.
It sounds like I'm complaining a lot, but this saw has been a good investment. It's made a lot of sawdust over the years, works fine, is easy to adjust, and is reliable. It's not a real cabinet saw, but it's a decent, portable contractor saw. There are a few areas that can be improved, and in the last 10 years, Ridgid may have improved them. I don't know. I do know that there wasn't a Craftsman saw at the time that could touch it in terms of quality, and there wasn't a Dewalt saw at the time that could match its price.
