Grease Gun Storage
Markgyver
Colorado
How does everyone store there Grease Gun?
I have seen those brackets to hold them on the wall are they any good? They dont look like they would work with a new tube of grease when the plunger is all the way out.
mrpowderkeg
Bismarck North Dakota
I have a cordless gun that has a case. I make sure it's squeaky clean before I put it in it's case. Other than that, if you use it often ( construction) it's an dirty tool.
plinker
Northern Wi
I had made some holder out of wood (1" board w/ hole sized to fit grease tube), but ended up using a plastic tool box as I need them portable now. I also try to keep them clean as possible.
superautobacs
Vancouver, BC
I just wrap mine with a rag when I store it, on its side.
Since I don't use mind often, when I go to use it the next time I get liquified grease dripping down from the plunger--I hate that. And more oozes out from the bottom as you squeeze the lever. I'm still on the original tube that came with the gun; maybe it's the cheap grease that's creating the spillage.....or is it an inherent problem for all grease guns?
I've seen those holders, but wasn't willing to spend that kinda money for a grease gun holder.
Snappy
S.E. PA
I hang mine on a vinyl coated hook, on the wall. It's been working fine for 8 yrs.
Art From De Leon
De Leon, Texas
I assure you that it is NOT the cheap grease, I use nothing but the red Mobil sythentic, and it drips all over also.
GN4WHLN
Alta Loma, CA
I have a pnumatic gun with Mobile 1 in it. I store it in a small plastic tub and wrapped in a rag. There always seems to be a little grease that come out when stored and though I keep it wiped down, a little film on it. This way the grease stays off other things and the gun does not ammulate dust.
uhcrandy
Here is what i did, I took a 5 gal pail, i took several sections of PVC pipe (2 & 3 inch) about the same depth as the pail. And glued them together all facing up. So i Have a couple of grease guns (1 air,1 pump) I also have several funnels. The grease guns hang from the open 3 inch PVC, in the pail and are up from the bottom of the pail. I keep newspaper in the bottom and change it when I remember. No pictures, I am at work.
rodm1
Not yet but I'm using a 3inch threaded PVC union with a cap on the bottom screwed to the wall. Just drop the gun in and no grease mess to pick up. Kind of expensive at $13. But I'm tired of grease running down the walls.
P.S. Are you suppose to pull the plunger all the way out for storage?
superautobacs
Vancouver, BC
Using PVC is a good idea; I may have to copy that.
Pulling the plunger out before storage--that might be a good idea, too? Sort of similar to how you'd push the tab on a caulking gun to relieve pressure.
Defender Chassis
Williamstown, WV
I know this has been discussed here before but I can not find it.....
http://www.greaseguncaddy.com/
KenS
I believe the plunger should be pushed back into the gun after a tube is loaded.
I'm probably misunderstanding this, but how would push the plunger through the grease? I have an old grease gun and the plunger is almost impossible to pull back once it's in the grease. The problem is that if I don't pull in back after use, it slowly sinks into the grease.
Any experts here have tips about the proper use and storage?
jay50
I throw mine inside an empty 50lb dog food bag under the work bench.
Nothing fancy.
GC_Anthony
On my grease gun the rod will pull the plunger out to load a new tube but it will slide through the plunger back into the gun so its not 2 foot long when full.
35mastr
Norcal
I also just hang it on the wall. Or just store them in my service cart on the bottom tray.
For the record. The plunger is to be pushed all the way in at all times.
The only time the plunger needs to be pulled back is to replace the grease cartrige. I usually just hold the gun with my foot to pull it out. Replace the cartrige and then push it back in.
nate379
Palmer, AK
I just have mine in one of the drawers of my toolbox. Just grease guns and adapters in there so I don't worry too much if they leak or whatever.
mooman
CHICAGO, IL
have a picture of this? I like this idea.
Brandon_Lutz
Forest Hill, Louisiana
Hang mine over the side of one of the many plastic drums we have in shop.
There is one near the work table that we hang all 3 over. That way if any grease comes out it goes in the can instead of one the floor.
Markgyver
Colorado
I just realized I have a empty sawzall case that I have had laying around that it fits perfect in.
nate379
Palmer, AK
I used to do that, but the drum would turn into a trash can and I lost a couple grease guns that way
