Jim Dawson
I just moved and am trying to figure out heat and air for my detached garage. My previous garage was 24X24 with a 10' ceiling. I had a conventional electric furnace with air and it worked great for both summer and winter here in the St. Louis area.
My current garage is 24X24 with an 8 1/2' ceiling, both walls and attic are well insulated but unfortunately unheated. I am going to be limited to an electric only solution and am looking at a mini-split as it looks like I could use my existing 50A service by adding a 30A breaker. If I go the conventional furnace/AC route I'd have to spend a lot of money upgrading the electric service and spending considerable more money for the system.
My question is, will a 24,000 BTU mini-split give me enough heat in the cold mid west winters? There are some pretty inexpensive systems available that look like I could install myself.
Below what temperature will the heat pump no longer heat well?
Thanks for any advice,
Jim
Jim
