Belt Grinder
hoston23
godley, texas
I am wanting a 120 volt belt grinder. but I want the belts to be easily removable so I can use multiple grits and change them out with ease. I just don't know where to start on looking for one
dodge610
North Canton Ohio
I have the HF belt grinder has been great for me. One foot note put a good belt on it the one that comes with it is not worth much.
2oolhound
BC Canada
I have a 42"x2" 1HP craftsman and I like changing belts fast too. Releasing tension with the spring loaded wheel couldn't be faster or more convenient but removing the dust shroud and replacing it took close to a minute, an endless minute so I removed it and shelved it. 6 months later the sealed bearings were a lot louder than when I first got the machine and I hate the thought of the time involved in pulling it apart, sourcing bearings and getting it back to newish condition so the dust shroud went back on and now I happily spend the minute to remove and replace it for belt changes. It doesn't bother me anymore.
So just some friendly advice, keep the dust shroud on. Even sealed bearings are not impervious to the fine abrasive dust that comes off them.
zkling
Do you have any ambition or means to build one?
A used coote would be nice.
I think the multitools are a bit pricey for what they are, but a nice compact unit. If they made a bench mount belt driven version, that would really be something IMHO.
I'm not a fan of the 2x48 standard kalamazoo units. The contact wheel is not easy to get to, tensioning and tracking system is tedious, just not all that great of a machine, again for the price IMHO. Now the belt driven units are a bit better, basically a coote style.
Just depends on what all you want and what you want to do. Is a contact wheel all that important to you?
Tinner
N.E. Wisconsin
If you want to build one, Google: KMG clone belt grinder. Lots of great plans and ideas that can be built with a minimum of tools.
H
hoston23
godley, texas
well I really want one with the grinding wheel on the other side. like a bench grinder set up because I want to replace the grinding wheel with a wire wheel. I'm not big on the grinder because they take off too much at one time. the one I have currently is wore out and shakes uncontrollably
Hammer1963
Kentucky
I definitely recommend a Jet grinder/Multitool combo. I have 3 sizes: 2" x 36", 4" x 36" and 4" x 48". They are great! As previously posted, you can find them at Trick Tool. Great customer service.
JCByrd24
Bath, ME
2nd the multitool recommendation, especially if you specifically want a grinding wheel on the other side. I have one on an old 8" Craftsman block grinder and it's amazing. The multitool itself is great, but it needs a good grinder to power it. I can't remember the amperage on mine right now, but you can't stall the thing.
d.mcfarland
Western PA
The Coote is "2"x 6"x 48" = $405.00 + shipping (26lbs.)". From their website. Not exactly pocket change for occasional use. Unfortunately I think the best way to go about it would be to try and find a used one OP.
exmaxima1
Midwest
You could easily build a basic 2x48 for $300 or less. The larger, more elaborate ones will cost more. You have to be creative and resourceful.
Having built a 1/2 dozen belt grinders myself, I understand. I just meant that the KMG clone would cost over $300 once you buy wheels, pulleys, motor, bearings, aluminum stock, etc. That's a higher end design that's far more than most DIY users would need.
If the OP is handy and creative, he certainly could build something from scraps, buy some wheels, and attach it to an existing grinder like I did to a Dayton 10"
zkling
What exactly you are expecting out of a belt grinder? A true belt grinder with a low grit even up to 80 grit belt will remove metal much faster than a stone will.
H
hoston23
godley, texas
I know it will eat metal, but I'm not big on the stone simply because they wear funny and do more harm than good. with a belt I can grind on a flat plane where the stone starts to round out. plus my dad buys cheap stones and they are ****
454ragtop
Carver, MA
Look around for a used one. I have a Hammond that uses 2" or 2-1/2" belts of most any length up to 60". Simple spring loaded tensioner, belt changes couldn't be any easier. Also have a Porter Cable vertical 4" X 54" with the biggest 1 HP motor I've ever seen, looks like the 5 HP Baldor on my compressor. Tons of cast iron on a pedestal, this one uses a threaded crank for the belt tension, a little longer to change a belt, but still simple and quick.
Jim
