hoston23
I am wanting a 120 volt belt grinder. but I want the belts to be easily removable so I can use multiple grits and change them out with ease. I just don't know where to start on looking for one
I was thinking around $300 with motor included. or not. I don't see me using it super often
BTW
Where is the best place to get paper for these type machines
If you want to build one, Google: KMG clone belt grinder. Lots of great plans and ideas that can be built with a minimum of tools.
Not likely to build for less than $300. More like $500
I definitely recommend a Jet grinder/Multitool combo. I have 3 sizes: 2" x 36", 4" x 36" and 4" x 48".
You could easily build a basic 2x48 for $300 or less. The larger, more elaborate ones will cost more. You have to be creative and resourceful.
well I really want one with the grinding wheel on the other side. like a bench grinder set up because I want to replace the grinding wheel with a wire wheel. I'm not big on the grinder because they take off too much at one time. the one I have currently is wore out and shakes uncontrollably
