The VISES of Garage Journal
General Geoff
Allentown, Pennsylvania
Email them and find out. Www.milwtool.com they have swivel bases, jaw inserts, etc on the shelf, I'm sure they have what you need. Question is whether the Chicago stuff interchanges. I know for a fact they have Chicago jaw inserts on the shelf. The swivel bases are actually pretty cheap especially for a small one like that. I want to say I paid $50 for a 140 swivel base for a vise I gifted to my dad, but I went down the shop and picked it up personally.
In case the new guys haven't seen it, here is a pallet full of Morgan 60s and 80s ready to be sent out.
I sent them an email requesting information about parts availability/compatibility for this vintage of vise, I guess we'll see what they have if they respond!
I did manage to tighten up the main nut play by shimming it with a cut down mild steel bracket. Probably not the way it should be done, but if it works, it works, right? With a new straight lock pin, it should be completely solid.
Also, I wire wheeled the jaw faces and it appears the jaw faces themselves are what's preventing complete parallel closure. They are very worn and chewed up, with boogered-up high spots near the top. So I reserve some hope that new jaw faces will resolve that problem completely.
Just noticed this on my Morgan 160 the other day. A sign from the aliens? Lol
Sent from my C1904 using Tapatalk
If you look at it at the angle the vise sits, it looks just like an alien looking down at my bench....
Quite the casting flaw haha
So, your'e not say'in it was aliens; but it was aliens...
zkling
Any ideas on fixing this or should I toss it up as junk?
Just for future reference, you can tell it had issues by the uneven (tapered) gap when it was closed and viewed from the side. You can try smacking it back on the slide to get it back perpendicular. Just use caution.
Preheat, get it back into position and weld. Cool slowly. You have nothing to lose and other than the same abuse that cracked it to begin with, it should hold up.
Pretty sure those wern't welded from the factory, that is a pressed steel slide vise.
vintage nut
west coast of canada
The did have an episode about aliens helping the nazis to develop time travel, so I wouldn't have a hard time believing they would theorize something like this..... LOL
wrenchguy
NW Indiana
If you think about it, that thing is hollow, and it's cast iron. Both things you don't want in an anvil. Even solid cast iron anvils are worthless for real anvil use.
Proper anvils are made from a solid piece of forged steel (there are exceptions though, such as the old ones that are a hand forged wrought iron body with a steel too plate, and some new ones that are cast tool steel)
I can almost guarantee you that those anvil vises have no rebound, and I could probably completely destroy one in an afternoon forging.
I agree they look cool, but I'd consider them to be a shop decoration rather than a useful tool
it was made for farmers over a 100 years ago, at that time there was a market for lighter combination tool like that.
BajaScout
San Diego, CA
Ani idea who made this vise? Looks like it had a metal ID plate.
Sent from my GT-P5210 using Tapatalk
Appears to be missing a part on the bottom of the vise. Not sure what this is for. Also still need hep identifying this vise.
Almost certainly a Chicom/Asian copy of an early US/Brit vise design. I've just never seen one so abused and still appear to be in one piece.
Thrumcap
Nova Scotia
Here's two 6" vises I picked up this weekend from an older gentleman cleaning up his shop. He didn't see any numbers at first, but said they were 12" opening, 3/4" handle, and old :headscrat off i went...
The first is a Canadian 6". Not a lot of references on this one.
The second one was in the woodshop. It turned out to be a 6" Emmert Tiger.
This one is well used....it does have some welding on the internal nut but that looks OK.
Today I managed to get the American Scale No. 79 dismantled, with the judicious usage of a 4 pound Persuader :evil: and a lot of tapping on the underside of the rotating jaw to creep the entire jaw off... Last thing off was the stuck pin out of the rotating jaw with one satisfying smack. Clean and mask the lot, and off to the blaster.
Thrumcap
:canada:
AmericanMechanic
Is there another application outside a vise where you'd find the taper pin that holds the static lead nut inside the vise base? Looking for one for a Columbian 505. Tried some Google searches but didn't find anything that looked correct.
Thanks
S4cruiser
NC
Better than before, but undoubtably not as good as it once was...
It should serve duty on my welding table just fine. Still need to pick up a pair of pipe jaws though.
Before (the jaws are closed as much as possible, but with a nice gap)
After
KMScott
Nice job S4cruiser, what welding rod did you use? The vise will be a good welding bench vise.
Baggs, wow nice job finishing the Parker, yes the shinny jaws look great but I am a serration guy and wish you showed what the jaw faces looked like. Looked like heavy cut serrations.
I sold this 954-1/2 today.
<a href="https://visejaws.smugmug.com/Chas-Parker-Vises/i-tjMd77k/A"><img src="https://visejaws.smugmug.com/Chas-Parker-Vises/i-tjMd77k/0/M/Parker%20954-500%2005-2015%20%284%29-M.jpg" alt="Photo & Video Sharing by SmugMug"></a>
CRSINMICH
Southeastern Michigan
Thrumcap: That No.6 Canadian looks quite a bit like an RAE made in Hamilton, Ontario. RAE is the only Canadian vise I know, though. I wasn't aware that Emmert made bench vises until you posted those pictures. And now that I have learned something new for today, I'm going to bed.
xxaler
Sutton Ontario
Henry is another rebranded one.
CRSINMICH
xxaler: I've heard of Henry but I don't know what they look like. Are you saying that they look like RAEs and Thrumcap's Canadian? Do you have pictures of a Henry? BTW where is Sutton? I'm quite near Windsor.
vintage nut
Henry is different. My dad has a 5" one. The company was called craft tools. Started by a patternmaker who made vises in a foundry in his back yard. Originally sold his vises to the military in wwii. As the war went on he ramped up production. Ended up making the majority of vises for the Canadian war effort. He sold the power tool division to porter cable around 1960, and stopped making vises then too.
Henry had no relation to rae at all. Very good vises! They basically took the best design elements from the different brands of English vises, and made the whole thing even heavier. Probably has about 15# on the equivalent record. I'd consider them my favorite of the English style vises.
Terrier is another Canadian vise. They are proper machinist style vises, but a bit lighter than the equivalent record.
I haven't seen a rae in person, but there are at least two more Canadian vise makers
topop101
NW Missouri
<a href="https://visejaws.smugmug.com/Chas-Parker-Vises/i-tjMd77k/A"><img src="https://visejaws.smugmug.com/Chas-Parker-Vises/i-tjMd77k/0/M/Parker%20954-500%2005-2015%20%284%29-M.jpg" alt="Photo & Video Sharing by SmugMug"></a>[/QUO
SMOKIN!That is so bad A$$ KMSNo body does it better!
skunkape1
Mnisota
I finally finished restoring the Craftsman 5198 I got in July. Photos and info about the vise were posted in this thread back then as the vise was an Ebay listing and apparently the 5198 is a highly thought of piece of iron. The paint used is "Chrysler Green" engine enamel, a color which was used on some Mopar muscle cars in the late 60's. Although the vise wasn't cheap, I am very pleased with the vise and the outcome of the restoration.
After:b43a59bb-4c25-4432-892d-91db2fc09804_zpsf3eqku5v.jpg42820840-d846-45de-9e4f-6d0e1eee0597_zpsbvzci1sz.jpgf378d3d3-3255-4e52-a271-a7bd816b42ee_zpsqdgzi3jg.jpgf3c40f9d-c257-409a-9da1-71ba8b0ca3e2_zpskpqbvl6b.jpg
And following user Econotrk's intelligent lead, I am posting a few photos of the 5198's casting numbers for research purposes.aedca9bd-ccfe-45d5-b335-764566a0bbe9_zps6uxayzyz.jpg348ef5ba-1a8a-4dce-8730-4591a0e30747_zpslhw0af95.jpg5ef81e5f-134d-44fd-b150-373f2df85622_zpsihnlmozs.jpg
CNGsaves
KS and OK
^ ^ ^ Fabulous . . . AWESOME . . . all other superlatives !! :thumbup:
That model is one of my favorites and on my want list.
Hemi49
Rush (Rochester), NY
Before:
After:
SKUNK........Very nice job!
oldldh
Fairhope, AL
That 5198 is gorgeous!!!
I really hate you...
I really do...
As it sits, how much do you have in it???
107 pounds of Superior Clampdom!!!
xxaler
Sutton Ontario
Sutton is an hour north of Toronto. Vintagenut's post explains it really well.
I've seen a few rae vises and passed them up not thinking they were much at the time, same with Henry's, but now that I know... Thank you!
bagged89s10
CT
Thanks Kevin. I wish i took more pics and better pictures but you can see them in these 2 pictures. This one had nice sharp serrations.
Your Parker jaws are a real work of art though. They look factory fresh! :thumbup:
bagged89s10
CT
bagged89s10
CT
Before:
After:
Badass! Great work! :rocker: :thumbup:
oldldh
Fairhope, AL
AS for THIS guy... :spit:
And it's a Swivlen B@$t@rd! too! :pimpflash
:evil:
Yes, my son, it is a "Swivilin" B@#tard"...
All my vises are fixed base...
But...
The Craftsman 5198 and the 209...
Are the only two spinners I'd feed...
Well, maybe a 5197, too...
CRSINMICH
Skunkape1: You did a really nice job on that Cman! It's a beaut. I hope you made a typo about Chrysler Green cuz I'm seeing light blue. My eyes have been going bad fast lately but I didn't think I was going color blind too. Maybe it's a photo/computer monitor effect. Anyway, good job.
xxaler: I thought that Sutton sounded familiar. I must have seen road signs for it on the way to Algonquin Provincial Park. Uh, any speckleds up your way? I do own two well used tying vises.
