General Geoff
Email them and find out. Www.milwtool.com they have swivel bases, jaw inserts, etc on the shelf, I'm sure they have what you need. Question is whether the Chicago stuff interchanges. I know for a fact they have Chicago jaw inserts on the shelf. The swivel bases are actually pretty cheap especially for a small one like that. I want to say I paid $50 for a 140 swivel base for a vise I gifted to my dad, but I went down the shop and picked it up personally.
In case the new guys haven't seen it, here is a pallet full of Morgan 60s and 80s ready to be sent out.
I sent them an email requesting information about parts availability/compatibility for this vintage of vise, I guess we'll see what they have if they respond!
I did manage to tighten up the main nut play by shimming it with a cut down mild steel bracket. Probably not the way it should be done, but if it works, it works, right? With a new straight lock pin, it should be completely solid.
Also, I wire wheeled the jaw faces and it appears the jaw faces themselves are what's preventing complete parallel closure. They are very worn and chewed up, with boogered-up high spots near the top. So I reserve some hope that new jaw faces will resolve that problem completely.
off i went...
and a lot of tapping on the underside of the rotating jaw to creep the entire jaw off... Last thing off was the stuck pin out of the rotating jaw with one satisfying smack. Clean and mask the lot, and off to the blaster.
