I've noticed that many of the lower cost Chinese drill presses these days seem to have a lot of quill slop. At least compared to older Taiwanese models I've seen.
Recently I bought a cheap DP and it runs ok and gets the job done, but it has way more slop than my older Taiwanese one. I thought maybe I just got unlucky, however I've since had a look at a few others in local shops and many of them (even ones costing more than mine) seem to slop around to a fairly similar degree.
At first I thought it was a run out issue but soon realized that "run out" and "quill slop" are two different things, and on this DP the slop is quite a lot larger than the run out.
So just wondering what is the deal with quill slop? How much is acceptable in a cheap DP, and what is it's relation to run out. I mean: is run out still the more detrimental issue? And just how bad does the slop have to be before it's a worse thing than the run out?
It seems to me that if quill slop is of similar magnitude to run out then it's probably fairly irrelevant. And it's probably only an issue if the slop get quite a lot greater than the run out that? Anyway just thinking out aloud here, but does that sound about right?
