Best lube for toolbox drawer slides
Dan Jacobs
I have an old Snap On Taco wagon tool box The slides are not the ballbearing type They are old style plain slides. I've cleaned them but they sure slide hard
Any suggestions on lube? Don't use the box everyday
Darr247
I've never had white lithium dry and become sticky; my beef with white lithium is it has no anti-corrosion qualities. Wipe it off the slides 5 years later and you'll find they've rusted while covered by it.
zkling
I did mine in 2002 on my 1960 Craftsman with white lube. Still works like new.
Craftsman boxes, especially their top boxes (due to lack of "real" welded in runners) have the largest ammount of clearance in the slide channel fit. On a fully loaded drawer you may not be able to recgoinze the increase in drag as much.
Since the OP has an inferior snap on box, he will really see a difference due to the tighter fitting slide channels, esecially on the "heavy duty" drawers.
Ponchoguy
I've got a Matco, Husky, Snap On and Craftsman box. From what I remember, the older Craftsmans have a full channel where the slide goes into, the later ones do not. However, all of the brands I've owned were lubed the same time with the same lube. No issues.
There goes that theory.
Ponchoguy
Also, a friend of mine used ski wax and said it worked well. I want to say Wurth among others makes a "dry lube" too.
monkeyspanners
Oxford, UK
Britool recommended vaseline on their draw slides which i used to start with, then just used white spray grease. After 20 years i have retired the box as the bottom rusted out. (I do a lot of farm work)
zkling
The majority of older craftsman TOP boxes did not have full slide channels, they used stamped louvered style tabs bent out from the inner wall for slide channels.
It's not a theory, it's based on experience. You are still disillusioned about your beloved craftsman boxes. I've been through more friction slide boxes than I can count, and the PITA factor on all slide related was grease. Worst ones came from body shops, as the abrasive grit got attached to the grease and wore the slide channels paper thin or clean through.
Ponchoguy
You mean the full channels that these (and every other CMan box from the 60's and up) have that you obviously have no experience with?
zkling
Explain this 1975 then.
Ponchoguy
Why? It's one of the ever so common 10 drawer top boxes. Still waiting on your explanation. :spit:
Because you made the claim. The two 10 drawer units I have are full channel. So is the six drawer in the photo.
Still waiting for your explanation.
zkling
But you said, and I quote...
Last time I checked 1975 was 'up' from the 60's. Hence why i earlier mentioned that MOST of the older top boxes had folded channels. There were a few from the 60's that were built better than most, but those are in the minority that are out there.
You can use your grease, i will stick with the wax :beer:
zkling
BTW OP, snap on produced a care guide for friction boxes, and recommended wax for lubrication.
Ponchoguy
Last time I checked, there were plenty of 60's box (and 70's) that had the full channels like I described.
Yes, we will all use what we will. After all, the original slides on my cabinets are still there and slide like new. The grease couldn't have harmed them...
justme-
Boston suburbs
I did a test about 6 months ago on a matco side box. Each drawer got different lube bases on a previous thread. White lithe, fluid film, viper lube, super lube. Big drawer still has white lithe, others are now FF and work much smoother. Only have the white on because I don't want to clean it off..works fine, but FF is smoother. Didn't have wax available, but I'll give it a shot when I relube sometime.
smokeyburb
Southeast AZ
Don't use any greasy lube, ever, because it will hold dirt & dust and will also get sticky/hard/crusty even in a clean shop environment. Instead, keep the slides clean and use a dry lube. It will sound weird but I have been pleased with using Pledge furniture polish inside and out on my boxes.
jn50308401
Cleaning out the old gunk is going to pay off better than applying more lubes/grease/wax. The boxes I'm doing were greased with wheel bearing grease and it was a mess.
Power washing, scrubbing the channels with a brass brush and acetone and a million old towels later the drawers open and close nicely without any lubricant.
Check the channels for bends and cracking as well. I used a small hammer and a piece of wood to straighten a couple channels.
Per the Snap on instructions I used parrafin wax for the slides.
Sent from my SCH-I545 using Tapatalk
joebachor
toledo ohio
gulf wax . its a paraffin wax. its cheap and you can get it from Kroger, Meijer, Wal-Mart or amazon. look for it around the canning section in the stores. snap on puts paraffin wax on at the factory and recommends its reapplication periodically. its what I use on all my boxes with friction slides not just my snap ons.
