Best lube for toolbox drawer slides
zkling
Any thoughts on using Johnson's Paste wax?
Don't think it would be a good idea as it is more of a protective sealing wax based in carnuba than it is a lubricating wax. It doesn't build well on metal. Just as there are different types of oils, there are different types of waxes. Just get a stick of doorease or the like.
Terbls59
What is the consensus on silicone spray?
I was going to use white lithium grease on my drawer slides because it doesn’t run and is less messy than other gr.
But if silicone or some kind of spray wax would work just as good or better I would rather use that.
*I know this is an old post, but I would still appreciate any feedback! Thank you so much!
Ricky Joe
Roanoke, Va.
.Try Kroil graphite lube. Any lubricant will work; it really depends on how much maintenance you are willing to do. I like graphite lubes because you do it once and that’s it.
seber
Deep East Tx.
I just cleaned up another box someone had used that $&$R%^% white lithium on. What a damn mess. Gets hot and runs all over the place. Takes hours to clean up. Snap-on recommends paraffin wax, as in candle and I've found it works well for me going on 55 years of use.
I just cleaned up a Kennedy box, the slides were sticky, and covered with black sludge. Cleaned w WD-40, then lubed with Paraffin wax. Don't use beeswax, its sticky.
bob15
Northeasten, CT
This stuff works well on an old Kenndy box's friction slides. Also won't attract **** like white grease (or grease in general) does.
RAS61
Low Country, SC
I went through this last year when I picked up an old Valley top chest and the consensus was wax. I bought a puck of what was supposed to be best (can't remember brand name) and applied. I was a little disappointed with the smoothness, ok but expected better. I think it has a lot to with the limits of friction slides, and maybe mine aren't the best to begin with. I'm sure grease would be slicker, but runs the risk of gumming up over time. For a box in an industrial setting with a lot of dust (like the auto body shop mentioned) grease is probably a mistake, but in a home shop or garage I think grease would be fine, just may need a cleaning every 5-10 years, so depends on how important that little extra slickness is to you - my 2 cents
Outahere
Idaho
As someone that has cleaned hundreds of friction box slides. Do not use white lith grease, or any grease for that matter.
I agree. I put grease on some of my toolboxes years ago, and it has hardened (from oxidation I presume) to such a degree that I can barely open some of my drawers.
65Goat
I know the thread is "lube" but does anyone clean the slides prior to lubricating them? Perhaps a gentle solvent prior to lubricating them?
If so what type of cleaner do you recommend?
Firebrick43
West central Indiana
Do you guys run your engine oil for 15 years????
I pull my slides and wipe out the old grease and with a q tip and acetone/brake cleaner. Then take and reapply some synthetic grease with a syringe. Do it every year at the beginning of the year. Slide great. Did this with my kennedy work box for years. Every one had the same box and the slides after 15 plus years had started wearing out. Mine were still good with hardly any wear. If I hadn't had so many tools I wouldn't have turned in my taco for a large 72" box as the ball bearing slides where not as strong
AirMech#406
Yup. I used to do it every year on my Waterloo box and later my Craftsman. I would remove the old grease with acetone or rubbing alcohol and then reapply a light coating of moly grease.
My new Tekton/Rousseau box is a bit of an odd duck though since it does not have traditional drawer slides. It came with no lubrication/maintenance instructions, and from what I can tell the carriage system it uses relies on having a clean dry surfaces, so I have not touched them with any lubricant, dry or otherwise. It doesnt really need it anyways. It glides very nicely without any lube at all.
2ndGearRubber
Pittsburgh
Depends on the setup. For small boxes, and small drawers, not so bad. I have 30 or so to deal with, several 72x30 drawers, meaning they need 100% unloaded. Even some of the 36x30 need unloaded. I just spray them with some penetrating oil if they ever feel sticky. A couple of cycles smooths them right out. Now, these are modern ball bearing snap-on slides. If they get problematic, I just warranty them.
For my old snap on boxes with friction slides, I cleaned the rails and guides in the box/drawers, and scuffed some candle wax on the slides themselves. Worked pretty well, but it's a home box. Smelled like candle wax though, who'd have thought?
AirMech#406
Yeah, I can definitely see how that would be a huge pain to have to unload every 72x30 drawer. My back hurts just thinking about it.
larry_g
oregon
When cleaning the slides inspect them also. Run your fingers along the sliding surface and check for burrs or galling. A minute with a wet stone can do wonders to smooth things out and reach a much lower friction level. Just like deburring a newly machined part, its second nature to a machinist.
lg
no neat sig line
VolvoRyan
Kentuckiana, USA
How are y'all applying paraffin wax? I've got a 1976 Snap-On roll cab and top box with a MAC side cab. All the drawers could use a little TLC.
Thanks!
-Ryan
seber
Deep East Tx.
We get plenty of 100 degree days here. When it's that hot, the candle almost melts in when it is run along the slide. When I was further North, I made sure to leave some chunks in the line to get mushed out as the drawer was worked.
ScottFW
NoVA
On my Craftsman friction type drawer sliders I use a Teflon dry film lube that's marketed for bicycle chains (Finish Line brand IIRC). Pretty much the same type of lube that's in the DuPont spray can, but being for bike chains it comes in a dropper bottle that lets me apply it more precisely versus a spray.
dnschmidt
Phoenix, AZ
Can't say I've ever had the problem since I'm a neat freak but all I can add to the conversation is that Accuride (the originator of the full extension drawer slide) uses white lithium grease. Nothing against anything else (which likely works fine) but these are the experts and that's what they use.
seber
Deep East Tx.
Actually Accuride uses wheel bearing grease, but only in ball bearing slides. They pretend they have never made friction slides.
gda659
in the forest
All the roller bearing slides in the used Snap On boxes I bought in early 2018 were gummed up with grease, almost unuseable. I pulled them all out and cleaned them with diesel and they've been rolling beautifully ever since.
calandrod
Kansas
I did a test about 6 months ago on a matco side box. Each drawer got different lube bases on a previous thread. White lithe, fluid film, viper lube, super lube. Big drawer still has white lithe, others are now FF and work much smoother. Only have the white on because I don't want to clean it off..works fine, but FF is smoother. Didn't have wax available, but I'll give it a shot when I relube sometime.
Anyone know where that thread is?
fireplug
I have three bottom drawers of my Beach roller that must have suffered water damage in prior ownership. Top grooves of the slides had rust and the drawers worked like junk. Finally did something about it. Wire brushed the scale off, leaving shiny but slightly pitted metal.
I then experimented with lubes. I used candle wax (possibly paraffin but not way to say for sure), dry graphite spray, the two combined, and white lithium.
Hands down the white lithium was the best.
fireplug
Quite possibly, however the previous owner of my other chest used the same thing and there is no evidence of such. I've owned that one at least ten years. I'd rather clean and relube every fifteen years than suffer crappy drawer action. As they say YMMV.
dvblanch
florida
Have cleaned old friction slides with WD40 toothbrush &rags Reassemble & lube with Fluid Film wipe any excess around on drawer sides &inside of chest for corrosion protection. Once a year or so hit slides w little shot of FF works well enough
Pexto
Definitely YMMV. I've refurbished a number of old toolboxes with crusted grease all over the drawer slides that took a great deal of effort and time to remove. Hence my dislike for grease. But some of these were probably 50 years old, and who knows what combination of random lubricants had been indiscriminately applied over that time. Not quite the same as a careful application of a quality grease, I'm sure.
I'll readily admit that a thin coat of a quality modern grease will probably work well for a number of years, and may be a good choice for some folks. My garage is fairly dusty (dirt road, dirt driveway), and thus I prefer to apply paraffin wax that I know will never degrade, will never attract dust or grit, and can easily be refreshed in a few minutes should I ever need to.
Shelbylex
I would recommend 40% of 3-in-1 oil, 10% grease, 10% WD40, 20% liquid film, 19% vazeline and 1% unicorn sweat mix.
Alternatively, you can use Gulf Wax - works pretty well on my 1955 KR-56 and 1963 KRA 58B. I suspect I used it on K-200 roller, but do not remember for sure....
Shelbylex
... look at the image provided by lilredex here on the bottom of left page is SO recommendation
seber
Deep East Tx.
Every time I have to clean a box that has been lubed with grease I wind up doing a lot of swearing and hating on the jerk that put it there. It is the worst kind of job I know of short of plumbing. It is always crusty where it should be working and sloppy messy where it ran out and separated. My boxes have always been lubed with paraffin. It is permanent and works just fine.
KnurledNut
n/a
Tip: A heat gun will melt just about any grease/wax and speed up friction slide cleanup.
WWheeler
Middleofnowhere USA
Got a link for that unicorn sweat? I have everything else and want to give it a try. :devilish:
I use a dry chain lube on my slides these days. I also used a moly grease before and while it wasn't as neat and clean looking it has worked really well also for a really long time now. Any grease or lube that won't pick up dust is what I've always looked to use.
Walkers
Cave Creek Az
I have found unicorn nut sack oil to work much better, but watch out for the hooves when you are trying to stretch it into the box to get that half of the slides.
fireplug
Absolutely the best threads of all time. Perhaps the only better
example of the number of experts hiding in the woodwork would be the immunologists these past couple years!
