Mobile workshop
aidindog
50338f0eed6ae15ebe0430e269ac64b1.jpgcdf2f9b05db8aa8bd6d6af1dd2d956df.jpg09d5b08199e03e60b2c5cdc7b7e3faec.jpgeae0a8478557366f7d272a88b7d62a84.jpg PLEASE HELP ME TO IMPROVE MY NEW MOBILE WORKSHOP
A
aidindog
I'm with you needs more light we only have 12v auxiliary battery on board 975da70d5bdc592a5e90912be64068b2.jpg so the voltage drops while truck not running and we have 12v fridge on truck so it ***** the juice 789802be90ebf73588b3f83af2a49876.jpg
Thumper68
Duluth MN
Can't give you any suggestions without knowing what kind of work you are doing.
But it looks good so far.
A
aidindog
Service and repair high rail vehicle
A
aidindog
I'm pretty much self sufficient on my truck I need more strip led but need solar or something similar to keep the battery charge while truck is off
wttwoa
alabama
maybe if you have access to 120v reliably, add a power strip to hook up more lights and use a extension cord kind of like how ron paulk does on his mobile woodshop.
and also they are constantly updating fridges to be more efficient so it might be worth looking up if they have made a better new one, and like you said getting solar panels would be worthwile.
wttwoa
alabama
Wttwoa send me the link please
its in the youtube link i posted about ~13:50 in. he just has a 100 foot extension cord on a garden hose reel that passes through the side of his trailer and then plugs it into a junction box with a built in breaker box, i think its called a gfci circuit?
7echo
coastal Georgia
Solar on the roof to keep the batts up. LEDs for lower power consumption.
You guys have some awesome trucks there.
A
aidindog
I have to wire the truck and put power box then I can put PowerPoint and RCD circuit breaker
wttwoa
alabama
also do you ever have a problem of the drawers coming open and tools going everywhere after you drive around in it?
Thumper68
Duluth MN
I would mount a getset on the tongue bit noisy but better to have that power at hand.
We had a propane powered Honda we used on jobsites without power.
wttwoa
alabama
Yep I do
for the tool boxes, what if you added some flush mounted d rings on the floor and some d rings on the wall above the tool boxes, and use those yellow pull straps to cinch it down, not the ratcheting type but the kind you just pull tight so you dont over tighten it and bend your tool box any, just enough so the drawers wont come flying out.
Carves
Central West NSW .. Australia
X 2
Straps or a steel rod or something.
... and if the toolboxes are staying there ... I would probably remove the casters.
As for your lighting problem,
... How about reducing your dependancy on electrics - and put some sky lights in ??
Maybe the caravan type or something ??
http://caravansplus.com.au/catalog/index.php?cPath=986_38_99
Lippyp
Shropshire, UK
I agree, you need a generator, I know a lot of British Telecom and Railway trucks over here have an external compartment with a small generator built in, exhaust is often routed up to roof height so the fumes disperse and louvres in the door for cooling/air entry or even an external air supply.
A
aidindog
We have
15kw generator on truck only use it when there is no power available ,with tying Down the toolboxes and other equipment I use those Eye bolt type tie point with cheap tie Down ratchet.i have 24 to 220v inverter in truck the yellow box it charges my labtop and battery's while I drive from job to job so really I need power for my compressor and my scale
