Mystery Tool Of The Day
Skyline
Here's another unusual tool:
Frank
Mesquite, TEXAS
Here's another strange set of pliers. Made entirely out of plastic, and labeled "Ouch Saver"
Yeah, I remember those. Surprised Billy Mays wasn't hocking them on TV. You use them to hold nails when you are driving them in case you are prone to always wacking your hand with a hammer. Suppose its handy for the drunk carpenter.
krusty the clown
Member Emeritus
niangua, mo
nope......as i previously posted it's for holding a wire while you pierce the insulation with a test light. it keeps you from stabbing your finger, hence the name "ouch saver".
pipehack
chicago
I've seen those made by another company . ( can't remember who) But it was at a plumbing supply house used for putting on angle stops. ( some folks call them supply valves )
JMartin
Greenwood Village, CO
Skyline,
I hope it is okay if I hop on your thread. What's this brass tool? All three ends are a different size. There is either a 6 or 9 on the back along with another founders? mark.
Thanks,
Jay
porschedude996TT
Santa Maria, California
These are MAC Wrenches, the RT122 and RT142, 3/8" and 7/16". Both are about 5" long. Were they designed for a particular purpose?:
My guess is for brake line fittings and such, but just curious if anyone has more information about these.
They are still used by a company called Swagelok for their flareless tube fittings and they call it a "Ratchet Wrench" see link page 8
LINK http://www.swagelok.com/downloads/webcatalogs/EN/MS-01-169.PDF
Junkman
Northeastern CT
Skyline,
Thanks,
Jay
That is a spud wrench for removing heating oil tank fill caps in the old days when there was no standard, and every company had its own design. When a customer changed oil supply companies, they needed to have a tool to take the other companies caps off to install their own. Sometimes they just left the other companies on and just used their wrench assortment to find the correct one. Today, the cap that most companies use is made by Scully. By the way, the caps were usually set in concrete in the lawn, with the tank buried below. Today, most tanks are in the cellar of the home..
snapmom
Florida
A so socket. 9/16 & 13/16, is spring loaded. Would give you the model number but that would take the fun out of it.
Skyline
I guess this is some sort of drilling guide, but I was curious as the purpose and use:
Skyline
-B-
Northshore of Boston
Bench block used for removal or installation of roll pins and the like in parts some can also be used as drill guides / tap guides to insure proper tap angle.
wanna sell it I am in need
Skyline
Here's another. It counts rotations as you turn the shapened end. An older Craftsman piece:
DynoDale
Pittsburgh, PA
Speed indicator. Put the end on a rotating shaft to count the revs while you use a stopwatch to measure time. There are other attachments like a rubber wheel to measure surface speed too. Not much use for these anymore.
Skyline
Snap-on Extended Reach Crow Foot socket, 1/2" drive 17mm - S6014, underlined Snap-on logo, no date stamp.
This one is obvious in terms of description....I would just love to know what it is used for:
Blacknwhitepit
Eastern Tennessee
It is a "Metric Valve Adjustment Tool" - for 6 and 8 cylinder Mercedes Benz. Also applicable to some Nissan overhead cam cars. - Got this straight from one of my old Snappy Catalogs.
-BWP
caper
cape breton
Anyone recognize this puller?
With that roller bearing it looks more like an installer than a puller.Hard to say without knowing the thread diameter but it's probably a accessory drive installer,could be Power steering pump pulley installer or AC clutch.
Skyline
Here's another:
It's an air hammer bit of some sort, only markings are "Made in USA" and "Caution Wear Saftey Goggles"
Skyline
Can someone ID this MAC Tools specialty socket?
It's labeled SC136. Kind of like an O2 sensor socket, but it's 1-1/4", (1/2" drive):
bgott
Houston, TX.
I can't tell you the exact application of that socket. With that said, it's to R/R ported vacuum switches. It would most likely be for an 80s' carburated app.
Skyline
Here's another unusual specialty tool. My guess is that it has something to do with serpentine belts. Any ideas? MAC Tools SBT120M:
caper
cape breton
Serpentine belts on 88 to 92 ford tempo mercury topaz 2.3l engine.And if you try to do the job without it it's very risky for your fingers.
